aleksandera
Post by aleksandera » Sat Dec 29, 2007 1:26 pm
:shock:
fishbowl
Post by fishbowl » Tue Jan 01, 2008 5:13 am
There's an option in the "Material" tab in Blendigo to set the material type to "External." Just set up a dummy material in Blender with the *same* name of the material in the .igm file, then click the little "..." next to the External material box.. I tested it & it works with the juice.igm, just look for the "<name>" tag of the <material> in the igm file. :)
edit: Ahem, and a Happy New Year! *toot*
2kemon
Post by 2kemon » Fri Jan 04, 2008 11:52 am
...exported with skindigo - thx whaat!
I know it's too "low-poly" around the wheels and the aluminium material is probably too shiny, but I'm pretty happy with it, since I'm still learning ;)
Vanessa07
Post by Vanessa07 » Fri Jan 04, 2008 7:09 pm
Very good render
you use the background colour for lighting the scene? you can try with meshlights to make beauty reflects :)
You should add subdivision to the wheels (subsurf in blender)
good continuation :D
Post by Kram1032 » Sat Jan 05, 2008 6:31 am
nice! :)
Hint: make your aluminium mat an nk (al.nk), to get perfectly correct aluminium. :)
the blue material is too shiny, in my eyes, not the aluminium ;)
If you use a specular, switch to phong and put the exponent down to ~100 or 1000 ;)
dougal2
Post by dougal2 » Sat Jan 05, 2008 11:29 am
Just a little something to soak up spacre CPU cycles this afternoon. Also to test IGM use from MtI.
Believe it or not, this is suvakas' OJ material :?
Phr0stByte
Post by Phr0stByte » Sat Jan 05, 2008 11:34 am
dougal2
That is neet...... but what exactly is it?
dougal2
Post by dougal2 » Sat Jan 05, 2008 11:36 am
it's a cylinder i messed about with, with some chrome bars through it, sitting on top of a black phong-backed glass floor, lit by EXR.
Post by Kram1032 » Sat Jan 05, 2008 1:16 pm
nice :)
suv's juice was used for an oversized scene.
How big is this one? Even bigger, I guess?
It looks great! some sort of nice jelly :D
Maybe orange ballistic gel? xD
dougal2
Post by dougal2 » Sat Jan 05, 2008 1:18 pm
well, suv said his glass was 2cm high... at that size i got an almost totally transparent material.
This object is about 40 - 50cm long.
drBouvierLeduc
Post by drBouvierLeduc » Wed Jan 16, 2008 1:07 pm
I put that one in simple renderings thread because I really didn't bothered : I shamelessly didn't model a single thing on that scene (downloaded a few models here and there, put them in front of the camera, and voilà !). It took approx 15 mn.
You can clearly spot the bird model is low-poly. I'll try to re-model it sometime in order to complete the scene... Though I wonder how to achieve a good feather material.
a bird
Post by BbB » Wed Jan 16, 2008 8:09 pm
beautiful nonetheless. The grass looks very good!
kwez
Post by kwez » Thu Jan 24, 2008 4:28 pm
ok, this is the perfect thread, so I'm comfortable posting some stuff ;-)
so much to learn (blender AND Indigo) .. yeah !
testing a 'fractal pyramid' blender script I'm writing:
w. studio setup found on this board ;-)
kwez
Post by kwez » Thu Jan 24, 2008 4:31 pm
kwez
Post by kwez » Thu Jan 24, 2008 4:32 pm
and
same scene / HDR, different angle
Users browsing this forum: No registered users and 107 guests
