fishbowl
by fishbowl » Tue Jan 01, 2008 5:13 am
There's an option in the "Material" tab in Blendigo to set the material type to "External." Just set up a dummy material in Blender with the *same* name of the material in the .igm file, then click the little "..." next to the External material box.. I tested it & it works with the juice.igm, just look for the "<name>" tag of the <material> in the igm file.
edit: Ahem, and a Happy New Year! *toot*
2kemon
by 2kemon » Fri Jan 04, 2008 11:52 am
...exported with skindigo - thx whaat!
I know it's too "low-poly" around the wheels and the aluminium material is probably too shiny, but I'm pretty happy with it, since I'm still learning
- 3cycle.jpg (569.49 KiB) Viewed 5134 times
Vanessa07
by Vanessa07 » Fri Jan 04, 2008 7:09 pm
Very good render
you use the background colour for lighting the scene? you can try with meshlights to make beauty reflects
You should add subdivision to the wheels (subsurf in blender)
good continuation
by Kram1032 » Sat Jan 05, 2008 6:31 am
nice!
Hint: make your aluminium mat an nk (al.nk), to get perfectly correct aluminium.
the blue material is too shiny, in my eyes, not the aluminium
If you use a specular, switch to phong and put the exponent down to ~100 or 1000
dougal2
by dougal2 » Sat Jan 05, 2008 11:29 am
Just a little something to soak up spacre CPU cycles this afternoon. Also to test IGM use from MtI.
Believe it or not, this is suvakas' OJ material
- test1.igs.png (337.55 KiB) Viewed 5038 times
Phr0stByte
by Phr0stByte » Sat Jan 05, 2008 11:34 am
dougal2
That is neet...... but what exactly is it?
dougal2
by dougal2 » Sat Jan 05, 2008 11:36 am
it's a cylinder i messed about with, with some chrome bars through it, sitting on top of a black phong-backed glass floor, lit by EXR.
by Kram1032 » Sat Jan 05, 2008 1:16 pm
nice
suv's juice was used for an oversized scene.
How big is this one? Even bigger, I guess?
It looks great! some sort of nice jelly
Maybe orange ballistic gel? xD
dougal2
by dougal2 » Sat Jan 05, 2008 1:18 pm
well, suv said his glass was 2cm high... at that size i got an almost totally transparent material.
This object is about 40 - 50cm long.
drBouvierLeduc
by drBouvierLeduc » Wed Jan 16, 2008 1:07 pm
I put that one in simple renderings thread because I really didn't bothered : I shamelessly didn't model a single thing on that scene (downloaded a few models here and there, put them in front of the camera, and voilà !). It took approx 15 mn.
You can clearly spot the bird model is low-poly. I'll try to re-model it sometime in order to complete the scene... Though I wonder how to achieve a good feather material.
- a bird
- oiseau.jpg (64.73 KiB) Viewed 4857 times
by BbB » Wed Jan 16, 2008 8:09 pm
beautiful nonetheless. The grass looks very good!
kwez
by kwez » Thu Jan 24, 2008 4:28 pm
ok, this is the perfect thread, so I'm comfortable posting some stuff
so much to learn (blender AND Indigo) .. yeah !
testing a 'fractal pyramid' blender script I'm writing:
w. studio setup found on this board
- fract-pyr2.jpg (178.44 KiB) Viewed 4693 times
kwez
by kwez » Thu Jan 24, 2008 4:31 pm
kwez
by kwez » Thu Jan 24, 2008 4:32 pm
and
same scene / HDR, different angle
Users browsing this forum: Google [Bot] and 50 guests
