Blendigo 2.2.1 for Linux and Mac
New build for Linux, should fix a bunch of stupid errors that have been in the latest Blendigo on Linux builds. Please download, use install.sh and report bugs.
http://www.indigorenderer.com/dist/expo ... 2.1.tar.gz
Mac users:
http://www.indigorenderer.com/dist/expo ... -2.2.1.zip
I'm working hard to get Blendigo in shape. It's a great bit of software, but I feel embarrassed at the number of bugs in it.
A Windows build of 2.2.1 are coming. Changes:
* .igmesh support
* Bug fixes
* Installer script for linux
* Fixed mac os installer
* Fixed material preview on mac and linux
Sorry for the long delay in getting a stable Blendigo out.
Ben
Mac users:
* .igmesh support
* Bug fixes
Ben
Re: Blendigo 2.2.1 for Linux and Mac
Hi ,
I try it , manual copy the script ( blendigopkg , blendigo.py ) in the ......//blender/script
and run the "render with indigo" script ( blender 2.48 and 2.49b ) .
the script can't run :
BLENDIGO v2.2.1
Linux-platform: linux2 os.sep: /
File "/BLENDER/2.49b__64bit/.blender/scripts/blendigo.py", line 3825, in drawGUI
responsecurvepath = os.path.join(indigo.getResourcesPath(),"data\camera_response_functions")
File "/usr/lib/python2.5/posixpath.py", line 62, in join
elif path == '' or path.endswith('/'):
AttributeError: 'NoneType' object has no attribute 'endswith'
sys : ubuntu64bit Jaunty
BLENDIGO v2.2.1
Hi SrLazlo,
I'm working on it now - do you have skype so I can chat with you?
Ben
Ben
icq , 407895177benn wrote:Hi SrLazlo,
Ben
( but I'm live in Budapest/Hungary ( weak english knowledge , dictionary and online dictionary
Laszlo - can you download and run the installer again? I have made a bunch of improvements which should fix your issues.
You need to run ./install.sh to install it.
Ok , but can't work.benn wrote:Laszlo - can you download and run the installer again? I have made a bunch of improvements which should fix your issues.
I find the problem. My blender and indigo isn't my home folder and the script can't work .
I have a lot of version blender and indigo.
When I start the scripts ( script>render>render with indigo ) the error messages now :
BLENDIGO v2.2.1
File "/BLENDER/2.48__64bit/.blender/scripts/blendigo.py", line 3825, in drawGUI
File "/BLENDER/2.48__64bit/.blender/scripts/blendigopkg/indigo.py", line 19, in getResourcesPath
return open(os.path.join(os.path.expanduser("~"), ".indigo/location")).read().strip()
IOError: [Errno 2] No such file or directory: '/home/laci/.indigo/location'
sorry
Did you run the ./install.sh - you need to create a file:
~/.indigo/location
That contains the location of your indigo directory, like:
/opt/local/indigo/
~/.indigo/location
/opt/local/indigo/
Hi ,benn wrote:Did you run the ./install.sh - you need to create a file:
~/.indigo/location
/opt/local/indigo/
I change the install.sh with my Path and run it.
The new error messages in terminal :
Compiled with Python version 2.5.4.
Checking for installed Python... got it!
File "<string>", line 1, in <module>
File "/BLENDER/2.48__64bit/.blender/scripts/blendigo.py", line 65, in <module>
indigoLogo = Blender.Image.Load(os.path.join(assetsPath, "indigo_logo.png"))
IOError: couldn't load image
I find the "indigo_logo.png" > ~~ /.blender/scripts/blendigopkg/assets/
hi ,
If the blender is in my home folder , the blendigo work
When run indigo 2.0.12 :
( saved igs,mesh... in /tmp )
Error: SceneLoaderExcep:
CSModelLoaderExcep:
ModelFormatDecoderExcep for model
'/home/laci/Indigo2.0.12/Plane_0.igmesh':
Invalid format version. (In element 'mesh',
around line 81, column 5)
Plane_0.igmesh ::
oCS#####################################ss##################�?��?######
CSModelLoaderExcep:
Plane_0.igmesh ::
Can you send me the .blend file please SrLazslo? I am determed to fix this for you.
I'm guessing you are making assumptions about paths ben? I haven't had a blendigo installation fail on mac prior to this release. With release of Snow Leopard I decided to do some restructuring of my system layout and I no longer install blender directly in the applications folder. Can't think of anything else that would cause this to fail.
- pixie
There were times where we would install an app just by dragging it to the app folder... those where the times...WytRaven wrote: I'm guessing you are making assumptions about paths ben? I haven't had a blendigo installation fail on mac prior to this release. With release of Snow Leopard I decided to do some restructuring of my system layout and I no longer install blender directly in the applications folder. Can't think of anything else that would cause this to fail.
I sentbenn wrote:Can you send me the .blend file please SrLazslo? I am determed to fix this for you.
Hi !benn wrote:Can you send me the .blend file please SrLazslo? I am determed to fix this for you.
Read my pm ?
