Time to move on to linux Ono!OnoSendai wrote:Wow... I didn't know Wine could do the wxWidgets version of Indigo and display the GUI!
Indigo 0.9 test 6
- joegiampaoli
- joegiampaoli
Ahhhhhh! Lutojar
By any chance are you opening one of the sample scenes in indigo?
I sometimes get or at some point got this error with some included test scenes....
Try opening antialias_test.igs for a start and see what happens.....
NOTE: also don't make a desktop launch in linux through wine, better run it directly from a shell like:
nice -19 wine indigo.exe
Then open the file I pointed above from there....
- joegiampaoli
- joegiampaoli
Hi Ono,
when i run "indigo_console" as network master, it still reports periodicaly "Display took xxxx s". I think in console mode there's no need for "Display" as there is no window to display
.... only moment tonemapping is used is for PNG or EXR output (only all 5mins in my case). BTW, is it possible to dissable PNG output too, that renderer only outputs IGI without any need for tonemapping??? That would be cooool and a minimum in cpu-power-wasting
- Kosmokrator
just downloaded the x64 bit version of indigo and runs perfect on my system and windows vista ultimate x64!!!the machine is from fresh install!
thnx Nick!
thnx Nick!
mrCarnivore
Prompts are really awkward, when you want to do batch rendering (as can be the case with network rendering). So I would suggest only a warning message if there is absolutely no output defined and the image doesn't act as a slave.CTZn wrote:In that case a prompt would be usefull, in the case where you are not saving any image (by mistake).
BTW: Do rendering slaves need to save images or can they just send them through the network?
