Indigo 0.9 test 6
joegiampaoli
Post by joegiampaoli » Sun Aug 19, 2007 8:38 pm
OnoSendai wrote:Wow... I didn't know Wine could do the wxWidgets version of Indigo and display the GUI!
Time to move on to linux Ono! :wink:
Joe Giampaoli
My Indigo Gallery
joegiampaoli
Post by joegiampaoli » Sun Aug 19, 2007 8:48 pm
Ahhhhhh! Lutojar
By any chance are you opening one of the sample scenes in indigo?
I sometimes get or at some point got this error with some included test scenes....
Try opening antialias_test.igs for a start and see what happens.....
NOTE: also don't make a desktop launch in linux through wine, better run it directly from a shell like:
nice -19 wine indigo.exe
Then open the file I pointed above from there....
Joe Giampaoli
My Indigo Gallery
Lutojar
Post by Lutojar » Sun Aug 19, 2007 8:52 pm
are you running indigo directly from it's folder, make sure there is a inifile.txt inside the indigo folder
I'm sure :)
I run Indigo from same folder that I use in Windowz (on win partition),
and when copy Indigo folder to Linux partition - have same result :( (tearful crying)
joegiampaoli
Post by joegiampaoli » Sun Aug 19, 2007 8:54 pm
well......hmmmmm try downloading directly to linux from website unzip and do what I mention above..... You might get some missing dll errors, just google them up, and download them to your wine system 32 folder
Joe Giampaoli
My Indigo Gallery
Lutojar
Post by Lutojar » Sun Aug 19, 2007 9:20 pm
THANX A LOT!!!!! :D its working!!
joegiampaoli
Post by joegiampaoli » Sun Aug 19, 2007 9:23 pm
No Prob... :wink:
Joe Giampaoli
My Indigo Gallery
zsouthboy
Post by zsouthboy » Mon Aug 20, 2007 6:16 am
@Lutojar:
more than likely your problem was a permissions error.
next time, simply open a terminal, and chown the indigo directory.
zuegs
Post by zuegs » Fri Aug 24, 2007 2:48 am
Hi Ono,
when i run "indigo_console" as network master, it still reports periodicaly "Display took xxxx s". I think in console mode there's no need for "Display" as there is no window to display :wink: .... only moment tonemapping is used is for PNG or EXR output (only all 5mins in my case). BTW, is it possible to dissable PNG output too, that renderer only outputs IGI without any need for tonemapping??? That would be cooool and a minimum in cpu-power-wasting :lol:
SmartDen
Post by SmartDen » Fri Aug 24, 2007 2:54 am
zuegs wrote: skipped...
I could be very useful! I second the request!
Post by CTZn » Fri Aug 24, 2007 4:07 am
In that case a prompt would be usefull, in the case where you are not saving any image (by mistake).
zsouthboy
Post by zsouthboy » Fri Aug 24, 2007 4:10 am
yeah if we could set display period to -1 or something, that'd be nice :)
Post by Kram1032 » Fri Aug 24, 2007 4:15 am
-1 == infinite == no GUI !?
Kosmokrator
Post by Kosmokrator » Fri Aug 24, 2007 7:39 am
just downloaded the x64 bit version of indigo and runs perfect on my system and windows vista ultimate x64!!!the machine is from fresh install!
thnx Nick!
mrCarnivore
Post by mrCarnivore » Fri Aug 24, 2007 6:59 pm
CTZn wrote:In that case a prompt would be usefull, in the case where you are not saving any image (by mistake).
Prompts are really awkward, when you want to do batch rendering (as can be the case with network rendering). So I would suggest only a warning message if there is absolutely no output defined and the image doesn't act as a slave.
BTW: Do rendering slaves need to save images or can they just send them through the network?
vansan
Post by vansan » Fri Aug 24, 2007 7:09 pm
I have an issue with Null material - the region behind the Null material clears much faster than the whole image. :) I'll make some testrender today to show this.
Use MLT + BiDir + Hybrid.
Users browsing this forum: Majestic-12 [Bot] and 16 guests
