Gemstones
Gemstones
Hi
What you see is in the caveau of my house.
Taking into account the global scale of about 1.5 meters the stones should be between 25 and 40 cm!
Stones so big you what I found in the garden I planted tomatoes !!!!
Re: Gemstones
Why so big gemstones? You do understand that you won't get realistic looking gems at that size, right?
Re: Gemstones
wow! very good... delicious
add more white color to the product look even more premium
Re: Gemstones
Hi
I have to learn in Cinema 4D to create a set suitable for small objects.
Do you think that if the gems were a few millimeters the final appearance would change?
- pixie
Re: Gemstones
you should trycontegufo wrote:Hi
Re: Gemstones
Hi
After selecting, cm, as suggested in the previous post I have activated the project Scale option from the Edit menu, then 0.5 Target stairs twice. At this point the confirmation screen Cinema me the reduction of scale. The bottom square indicates the size of the set (21.459 cm, 14.625 cm, 33.863 cm).
The gem after reduction an average size of 4x3x2 cm. They are acceptable values for medium/low carat gems. Then launching Indigo interface "scenes info" we "Scene span" 0.45 m, 0.34 m, 0.34 m. then 45 cm, 34 cm, 34 cm.
Are larger values of the Set of Cinema but is also likely counting the space occupied by the two light and then the whole area becomes a big plus.
The biggest diamond in the world, Golden Jubilee, after cutting the diamond reached a weight so far failed to 545.67 carats (109.13 grams).
In the afternoon, place the image indigo renders now.
- Originalplan®
Re: Gemstones
Is this set too?contegufo wrote:Hi
Re: Gemstones
By default this is set in cm are no changes to the settings made for previously.
- pixie
Re: Gemstones
If these are the same as I found in archive3d they are off by a 10x factor. so it's a matter of set the scale to 0.1 in C4D.
Re: Gemstones
Here's the scene. I do not see any difference.
Strange previewing in OpenGL, a bug?
- pixie
Re: Gemstones
You can always compensate, you can give it more absorption.contegufo wrote:Here's the scene. I do not see any difference.
Re: Gemstones
Festival of diamond! Real scale.
Re: Gemstones
Perfectcontegufo wrote:Festival of diamond! Real scale.
