Gemstones
contegufo
Gemstones
Post by contegufo » Mon Jun 20, 2016 3:28 am
Hi
What you see is in the caveau of my house.
Taking into account the global scale of about 1.5 meters the stones should be between 25 and 40 cm!
Stones so big you what I found in the garden I planted tomatoes !!!!
Re: Gemstones
Post by Oscar J » Mon Jun 20, 2016 4:25 am
Why so big gemstones? You do understand that you won't get realistic looking gems at that size, right?
Zalevskiy
Re: Gemstones
Post by Zalevskiy » Mon Jun 20, 2016 4:26 am
wow! very good... delicious
add more white color to the product look even more premium :wink:
contegufo
Re: Gemstones
Post by contegufo » Mon Jun 20, 2016 5:17 am
Hi
I have to learn in Cinema 4D to create a set suitable for small objects.
Do you think that if the gems were a few millimeters the final appearance would change?
Re: Gemstones
Post by pixie » Mon Jun 20, 2016 6:57 am
contegufo wrote:Hi
you should try
Zalevskiy
Re: Gemstones
Post by Zalevskiy » Mon Jun 20, 2016 7:18 pm
Experiment with this button
contegufo
Re: Gemstones
Post by contegufo » Mon Jun 20, 2016 11:03 pm
Hi
After selecting, cm, as suggested in the previous post I have activated the project Scale option from the Edit menu, then 0.5 Target stairs twice. At this point the confirmation screen Cinema me the reduction of scale. The bottom square indicates the size of the set (21.459 cm, 14.625 cm, 33.863 cm).
The gem after reduction an average size of 4x3x2 cm. They are acceptable values for medium/low carat gems. Then launching Indigo interface "scenes info" we "Scene span" 0.45 m, 0.34 m, 0.34 m. then 45 cm, 34 cm, 34 cm.
Are larger values of the Set of Cinema but is also likely counting the space occupied by the two light and then the whole area becomes a big plus.
The biggest diamond in the world, Golden Jubilee, after cutting the diamond reached a weight so far failed to 545.67 carats (109.13 grams).
In the afternoon, place the image indigo renders now.
Originalplan®
Re: Gemstones
Post by Originalplan® » Mon Jun 20, 2016 11:21 pm
contegufo wrote:Hi
Is this set too?
contegufo
Re: Gemstones
Post by contegufo » Mon Jun 20, 2016 11:25 pm
By default this is set in cm are no changes to the settings made for previously.
Re: Gemstones
Post by pixie » Tue Jun 21, 2016 12:55 am
If these are the same as I found in archive3d they are off by a 10x factor. so it's a matter of set the scale to 0.1 in C4D.
contegufo
Re: Gemstones
Post by contegufo » Tue Jun 21, 2016 3:57 am
Here's the scene. I do not see any difference.
Strange previewing in OpenGL, a bug?
Re: Gemstones
Post by pixie » Tue Jun 21, 2016 4:14 am
contegufo wrote:Here's the scene. I do not see any difference.
You can always compensate, you can give it more absorption.
contegufo
Re: Gemstones
Post by contegufo » Wed Jun 22, 2016 9:47 pm
Festival of diamond! Real scale.
Re: Gemstones
Post by pixie » Wed Jun 22, 2016 10:28 pm
contegufo wrote:Festival of diamond! Real scale.
Sweet!
Zalevskiy
Re: Gemstones
Post by Zalevskiy » Thu Jun 23, 2016 12:24 am
Perfect :)
