small scenes wip
neepneep
Post by neepneep » Fri Mar 09, 2007 12:20 am
drBouvierLeduc wrote: By the way, neepneep, if you read this, I tried your fresnel lamp, but I get very hard shadows... Am I doing something wrong ?
Hey Dr,
Here are 2 tests with the fresnel lamp: first one is the lamp @ 8 meters, and second one is @ 16 meters.
So I guess this basically shows that the the closer the lamp, the softer the shadow but you will probably have to lower the power a bit.
PS. Great renders!!
drBouvierLeduc
Post by drBouvierLeduc » Fri Mar 09, 2007 2:09 am
first scene finished.
scene 1
Post by OnoSendai » Fri Mar 09, 2007 2:11 am
drBouvierLeduc:
zomg, that is totally awesome. You're a true master.
Stur
Post by Stur » Fri Mar 09, 2007 2:17 am
Awesome ! That's the word !
How the hell did you model the chair ? :shock:
drBouvierLeduc
Post by drBouvierLeduc » Fri Mar 09, 2007 2:43 am
How the hell did you modeled the chair ?
Basically, it's a net duplicated along a curve.
Once you've got he curve and the the net modelled, it's a matter of two clicks (in blender).
@Ono-Sendai : wow, a word from the master himself !
how to model a chair the easy way
Stur
Post by Stur » Fri Mar 09, 2007 2:49 am
Amazing :D
jurasek
Post by jurasek » Fri Mar 09, 2007 4:55 am
5 stars for me :shock:
greetz,
jur
Post by Kram1032 » Fri Mar 09, 2007 6:43 am
5?
I know, it's not possible, but:
100!
manitwo
Post by manitwo » Fri Mar 09, 2007 6:50 am
really nice drBouvierLeduc!
but, could you post it in a better quality? these jpg-artefacts are horrible.
drBouvierLeduc
Post by drBouvierLeduc » Sun Mar 11, 2007 1:24 am
two small, quick, tiny updates : I'm playing with blender's softbodies... To my surprise, they work quite well for cloth simulation. Welcome fabrics, curtains, clothes and towels !
second one is a parquet floor test, nothing special.
@manitwo : I posted a higher resolution one in the gallery
parquet floor
softbody test
manitwo
Post by manitwo » Sun Mar 11, 2007 1:47 am
drBouvierLeduc wrote:second one is a parquet floor test, nothing special.
test succeed.
drBouvierLeduc wrote:@manitwo : I posted a higher resolution one in the gallery
cool!! great work. could i ask what kind of material u used for your vases?
rusted
Post by rusted » Sun Mar 11, 2007 8:11 pm
hi drBouvierLeduc,
great work doc! i had difficulty to differentiate ref and renders! is it possible to look at studio setup for chair image.(or a blend file if possible).thanks :)
drBouvierLeduc
Post by drBouvierLeduc » Mon Mar 12, 2007 12:12 am
@rusted : here you are.
The yellow planes are lamps and the black planes are for reflections.
@manitwo : the vases are a phong material (exponent = 60, ior=1.09)
chair setup
rusted
Post by rusted » Mon Mar 12, 2007 5:23 pm
thanks for the studio setup!
drBouvierLeduc
Post by drBouvierLeduc » Tue Mar 13, 2007 3:00 am
Some more tests...
Yes, actually half of thoses posts should belong to some "indigo tests" subforum, but... it's a wip right ?
So here are some material tests :
First, an attempt to get sss petals.
As it's not possible to use a texture on sss materials, I blend two materials : one textured diffuse and one white sss.
The blend map is uniform grey, so the blended material is 50% diffuse and 50% sss.
Regarding the sss material, I have absolutely no idea if the values I use are physically corrects, I just played with them until I got something visually good.
It is a specular transparent (Rvb gain = 17000, ior=1), with uniform sss (value = 5000).
So the result *seems* correct, althought It's somehow biased.
I'll try to blend two sss materials (one white and one pink) with a real transparency map to see if it's better. (don't know if it's possible).
EDIT : damn, it doesn't seem to work... :(
btw the petals are not flat.
Second is a some fabric test :
On the left is a blend material of textured diffuse and gold.
On the right the same with some alpha map.
And last... a book wich was not that simple to model.
Well, all of this should be in the next scene.
That's all for now !
a book
fabric material (left is blend of textured diffuse+gold, right is the same with some alpha map)
left : texture diffuse, right : white uniform sss
blend of a diffuse and a sss material
Last edited by drBouvierLeduc on Tue Mar 13, 2007 5:42 am, edited 2 times in total.
Users browsing this forum: No registered users and 113 guests
