Problems with sun and Glass in V2.2.12
4 posts • Page 1 of 1
Frank Schroer
Post by Frank Schroer » Wed Mar 10, 2010 1:24 am
Hello,
i have a Problem with Version 2.2.12 and Cindigo 2.2 Stable
I habe a sun, (Infinite source) and a Glass-Material (Ghost-Glass from Download)
On the Glass are white points, This Points are not rendert in Version 2.2.1, he comes with the new Sun-Def
in the new Version. The points lie on the light layer of the sun. Layer of --away points...
U can see the points at the Picture--- what can i do?
Rendertime: 18 h at 4x E7 Cip, 6 GB Ram
Thx,
Frank
Regards,
Frank
http://www.cycot.de
Re: Problems with sun and Glass in V2.2.12
Post by zeitmeister » Wed Mar 10, 2010 1:48 am
Strange.
In which units did you model your scene, and what is your scene scale in the exporter settings?
And in which render mode did you compute this? Path-Tracing, Path-Tracing Bi-Directional, MLT or MLT Bi-Directional?
Post by Zom-B » Wed Mar 10, 2010 1:50 am
the ghost Glass from the MatDB needs Single sided mesh... normals facing to the cam, is this given here?
Do you render in PT mode? Try MLT+BiDir... should render just fine!
In this scenario I would use "normal" glass (with thickness), should render fine here :)
Frank Schroer
Post by Frank Schroer » Tue Mar 23, 2010 2:21 am
Hello
Thank you for your responses. It is up to the Render Mode
The Render-Mode MLT has no more white spots.
Thank you very much
Regards,
Frank
http://www.cycot.de
Users browsing this forum: No registered users and 61 guests
