[Tutorial]Compositing your render/scene
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
Soup
Post by Soup » Thu Feb 11, 2010 4:40 pm
I've seen some discussion about compositing techniques around the forum and thought I'd make a little tutorial.
The tutorial goes over three methods:
The alpha method - how to make an alpha render and use photoshop to put in a background
Environment maps - what they do
Image Planes - a cheat for getting an easy background and reflections without post-processing.
Enjoy!
Tutorial_compositing.pdf
(819.22 KiB) Downloaded 2733 times
Doug Armand
Re: [Tutorial]Compositing your render/scene
Post by Doug Armand » Thu Feb 11, 2010 5:12 pm
Very nice, professional and useful tutorial.
Doug
Doug Armand
Post by Borgleader » Fri Feb 12, 2010 4:51 am
I massively approve of this tutorial :D
Doug Armand
Post by Doug Armand » Fri Feb 12, 2010 9:20 am
Borgleader wrote:I massively approve of this tutorial :D
I massively approve of your approval :P
Doug
Doug Armand
Post by StompinTom » Fri Feb 12, 2010 1:05 pm
I massively approve of... pie?
fenerolina
Post by fenerolina » Fri Feb 12, 2010 11:53 pm
Very good tutorial Soup! Thanks.
wojtek-w
Post by wojtek-w » Sat Feb 13, 2010 12:55 am
big THX Soup!
benn
Post by benn » Sun Feb 14, 2010 3:28 pm
I too approve of this tutorial.
dakiru
Post by dakiru » Tue Feb 16, 2010 12:23 pm
Soup wrote:I've seen some discussion about compositing techniques around the forum and thought I'd make a little tutorial.
Enjoy!
Very clear and useful :)
madcoo
Post by madcoo » Tue Feb 16, 2010 8:23 pm
Many thanks for this neat tutorial!
Very useful!
:D
Visit my website!
http://www.fairview-3d.com Studio 3D
djegoo
Post by djegoo » Fri Feb 19, 2010 2:13 am
Hi
+1 for this helpful tutorial. Precise and Concise.
galinette
Post by galinette » Fri Feb 19, 2010 4:51 am
Dear all,
I'd like to render an object and composite it in a HDR environment. The problem is, I would like the object to cast shadows on my envmap's flat ground (concrete floor in a business district surrounded by skyscrapers)
In 3DSMax, which i used several years ago, you can define a kind of "Matte/Shadow" material. This is a very special material that is rendered as a semitransparent shadow composited with the background.
For instance, you can do stuff like that:
http://forums.3dtotal.com/attachment.ph ... 1244270455
I don't like the solution that consists in re-modelizing the floor, as this will not connect well with the other parts of the scene.
Regards,
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by Zom-B » Fri Feb 19, 2010 7:54 am
Do you think about something like this
I simply rendered a version with a white floor to get the shadows on "pure" white (tonemapping ist the hkey here!).
Then and cut the Objects out by a separate Alpha pass.
composing back in Photoshop for the final result :)
galinette
Post by galinette » Fri Feb 19, 2010 9:25 am
The image that is used for your objects in the compositing was rendered without floor, right? Then your render on white floor is used only to apply the shadws?
In that case it should work for me. I'll try that!
Etienne
Jeff Hammond
Post by Jeff Hammond » Sat Mar 13, 2010 9:37 am
Enjoy!
the method deemed a cheat seems the best way to go for me.. i've tried the other two with mixed results..
this tut gave me the idea of the image plane and it makes a lot of sense.. at the very least, you can actually see how things are going to line up prior to rendering.. everything else is too much guess work..
thanks for the tutorial
