absorption layer transmittance test
Messing with the absorption layer transmittance parameter.
The sss version is darker, but I assume that is from the scattering,
since I've never been able to get a pure white sss material.
In the sss version, notice how the blue scatters below the surface - its a thing of beauty & wonder!The sss version is darker, but I assume that is from the scattering,
Re: absorption layer transmittance test
Wow, cool test.
If anyone is interested, absorption layer transmittance is perfect for creating things like imperfections on human skin (freckles etc..), when applied to a glossy transparent material. hint hint.
Very cool !
skin test...needs tweaking but looks promising I think.
- skin_test.jpg (60.39 KiB) Viewed 24484 times
- zeitmeister
Promising!
Could you give us your sourcecode?
I didn't save the IGM and now it's lost. However, these are the settings from what I recall:zeitmeister wrote:Promising!
Glossy Transparent
IOR=1.08
Exponent=50 (I think)
Absorption=?? (almost white, relatively low)
SSS=Uniform 300
Abs Layer Trans=Skin texture downloaded from internet with gamma=1.0 (makes it brighter)
No bump map for this test
I think that playing around with the absorption will result in different skin tones. I have no idea what the scattering value should be for skin. 300 might be too low but high SSS values really slow down Indigo so I don't like to go above 300.
- zeitmeister
Thank you!
Can't wait till fused implements it into Cindigo...
- pixie
Then you'll be glad to know that he already had implemented itzeitmeister wrote:Thank you!
nice one Whaat.
However, I would recommend that the absorption layer transmittance texture only have surface-level colours, such as freckles etc.. The general pink (or equiv.) colour of the skin should come from the medium absorption colour, as in real life.
Yeah, I didpixie wrote:Then you'll be glad to know that he already had implemented itzeitmeister wrote:Thank you!
I need to get that mac build out!
- zeitmeister
Ah, that was the point...!
Jetzabbazackzack!
Jetzabbazackzack!
Realy nice test
awesome! what's your sss material settings?Musorgki wrote:Messing with the absorption layer transmittance parameter.
... In the sss version, notice how the blue scatters below the surface - its a thing of beauty & wonder!
Check normals, dude!
Thanks everyone!
The texture itself was 255/255/255 white with a 0/0/255 blue bar,
used as the absorption_layer_transmittance in a glossy_transparent material.
When I rendered it in the material editor, I got a lot of fireflies, but
rendering with metropolis true and bidirectional & hybrid false cleared it up.
I hope that helps!
The absorption is 0/0/0, scatter is uniform 300 & phase is uniform.SmartDen wrote: awesome! what's your sss material settings?
I hope that helps!
Made this for an example.
23 hours rendering with Nick's i7 as slave
- Ilogo
- ilogo.png (293.53 KiB) Viewed 23805 times
