absorption layer transmittance test
Musorgki
Post by Musorgki » Wed Dec 02, 2009 6:50 pm
Messing with the absorption layer transmittance parameter.
phong material with blue-bar-on-white texture map
sss material with blue-bar-on-white texture map
In the sss version, notice how the blue scatters below the surface - its a thing of beauty & wonder!
The sss version is darker, but I assume that is from the scattering,
since I've never been able to get a pure white sss material.
Re: absorption layer transmittance test
Post by OnoSendai » Wed Dec 02, 2009 7:22 pm
Wow, cool test.
If anyone is interested, absorption layer transmittance is perfect for creating things like imperfections on human skin (freckles etc..), when applied to a glossy transparent material. hint hint.
Post by suvakas » Wed Dec 02, 2009 9:58 pm
Very cool !
Post by Whaat » Fri Dec 04, 2009 2:21 am
skin test...needs tweaking but looks promising I think.
Post by zeitmeister » Fri Dec 04, 2009 4:04 am
Promising!
Could you give us your sourcecode?
Post by Whaat » Fri Dec 04, 2009 4:57 am
zeitmeister wrote:Promising!
I didn't save the IGM and now it's lost. However, these are the settings from what I recall:
Glossy Transparent
IOR=1.08
Exponent=50 (I think)
Absorption=?? (almost white, relatively low)
SSS=Uniform 300
Abs Layer Trans=Skin texture downloaded from internet with gamma=1.0 (makes it brighter)
No bump map for this test
I think that playing around with the absorption will result in different skin tones. I have no idea what the scattering value should be for skin. 300 might be too low but high SSS values really slow down Indigo so I don't like to go above 300.
Post by zeitmeister » Fri Dec 04, 2009 5:29 am
Thank you!
Can't wait till fused implements it into Cindigo...
Post by pixie » Fri Dec 04, 2009 5:44 am
zeitmeister wrote:Thank you!
Then you'll be glad to know that he already had implemented it ;)
Post by OnoSendai » Fri Dec 04, 2009 9:18 am
nice one Whaat.
However, I would recommend that the absorption layer transmittance texture only have surface-level colours, such as freckles etc.. The general pink (or equiv.) colour of the skin should come from the medium absorption colour, as in real life.
Post by fused » Fri Dec 04, 2009 10:26 am
Yeah, I did :)
I need to get that mac build out! :lol:
Post by zeitmeister » Fri Dec 04, 2009 8:47 pm
Ah, that was the point...!
Jetzabbazackzack! :mrgreen:
Jambert
Post by Jambert » Fri Dec 04, 2009 10:02 pm
Realy nice test
SmartDen
Post by SmartDen » Sat Dec 12, 2009 2:04 am
Musorgki wrote:Messing with the absorption layer transmittance parameter.
awesome! what's your sss material settings?
Check normals, dude!
Musorgki
Post by Musorgki » Mon Dec 14, 2009 11:26 pm
Thanks everyone!
SmartDen wrote: awesome! what's your sss material settings?
The absorption is 0/0/0, scatter is uniform 300 & phase is uniform.
The texture itself was 255/255/255 white with a 0/0/255 blue bar,
used as the absorption_layer_transmittance in a glossy_transparent material.
When I rendered it in the material editor, I got a lot of fireflies, but
rendering with metropolis true and bidirectional & hybrid false cleared it up.
I hope that helps!
Soup
Post by Soup » Wed Dec 16, 2009 10:07 am
Made this for an example.
23 hours rendering with Nick's i7 as slave :lol:
Ilogo
