Reflection material: doesn't work
7 posts • Page 1 of 1
dsp_418
Post by dsp_418 » Tue Jan 02, 2007 11:52 pm
I'm trying to create a simple reflection shader like this:
http://www.indigorenderer.com/blender_tut/phong2.jpg
or this:
http://www.indigorenderer.com/blender_tut/specular1.jpg
As the tutorial says, I've to turn on the Ray Transp, but I don't get that result. It doesn't reflect anything: by the way I've added some plane on the scene oriented toward the main object those act as emitters lights.
Moreover if I try to use the Ray Mirror the result is totally black.
Any hint?
dsp_418
Post by dsp_418 » Wed Jan 03, 2007 12:01 am
Ok, it seems I've fixed a bit: now it reflects, but the emitter light appears as a black shader ...
IanC
Post by IanC » Wed Jan 03, 2007 1:06 am
What do your materials look like? (Preferably the XML)
Do you have a sun lamp? If so, many people have problems getting emitters and lamps working together, due to the differences in brightness.
dsp_418
Post by dsp_418 » Wed Jan 03, 2007 2:32 am
Yes, I've a sun lamp.
To see the emitters object working properly I've to export as background and not as sunlight ... this sounds weird, since in those images it seems there's a sunlight as well.
Phil
Post by Phil » Wed Jan 03, 2007 4:38 am
Hi dsp_418,
have a look on this post:
http://www.indigorenderer.com/joomla/fo ... .php?t=768
Right now you can only change some value in the XML file manualy, to achieve some good results when you combine mesh emitters with sunlight.
it will not work with the actual blender exporter, sorry. :(
Regards, Phil
dsp_418
Post by dsp_418 » Wed Jan 03, 2007 5:03 am
Thanks for the help Phil!
I'm gonna read that post.
Anyway so far has been done a great job on the exporter and it works really good!
Phil
Post by Phil » Wed Jan 03, 2007 5:10 am
right now there is no line of code in the exporter from me. :lol:
but yes it works prety well!
You should also have a look on you xml file.
Regards, Phil
