Is anyone using fluid simulation?
benn
Post by benn » Tue May 12, 2009 11:23 am
I wonder if anyone will do a water jug with fluid simulation? That'd be quite a nifty trick. :)
Re: Is anyone using fluid simulation?
Post by Borgleader » Tue May 12, 2009 11:34 am
I'll see about that once my semester is done...ill have quite a short time to do it though -.-; i finish on the 20th...
Stromberg
Post by Stromberg » Tue May 12, 2009 9:00 pm
Ah.. maybe i could do one with realflow, but as i understand the animation export in cindigo dosnt work yet.
Post by fused » Tue May 12, 2009 11:31 pm
yep, its broken. but zou could still export a single frame. its not an animation competition, or is it?
Post by CTZn » Tue May 12, 2009 11:47 pm
In the same way, would motion blur work with a water sim ? I tend to believe not, since water sims do change:
1: the number and
2: positions of the surface vertices,
instead of transforming one given mesh, breaking all geometry matching between frames... but the question still applies for me, thanks.
I should have an entry for the competition, but using a sim is not scheduled for it.
handsomedave
Post by handsomedave » Wed May 13, 2009 12:30 am
I may try a fluid sim. I have two Q6600 machines now so I can let one grind away for a few days.
Post by suvakas » Wed May 13, 2009 2:00 am
A fluid sim should not generate any motion blur unless it's transformation changes. Currently motion blur is generated only for physical movement of the mesh.
benn
Post by benn » Wed May 13, 2009 11:05 am
Yeah - I was just looking at the wine glass that was done in blender and thought it might be a nice trick.
Motion blur doesn't work on deforming meshes yet. When we get around to a smart way to do that we'll probably get better animation support at the same time - maybe some kind of 4d acceleration structure?
(It's fun imagining data structures when i'm not the one implementing them) ;)
benn
Post by benn » Wed May 13, 2009 11:09 am
Post by lycium » Wed May 13, 2009 3:27 pm
benn wrote:When we get around to a smart way to do that we'll probably get better animation support at the same time - maybe some kind of 4d acceleration structure?
i was talking to nick about exactly this a while back, surely he would have mentioned it ;)
benn
Post by benn » Wed May 13, 2009 3:45 pm
Heh - yup I think that's where the idea came from :D
Post by lycium » Wed May 13, 2009 4:26 pm
now if only you knew someone who's worked through the details and could implement it for you... ;)
ahahaha ok i'll stop :P
Post by suvakas » Wed May 13, 2009 9:06 pm
Motion blur for deforming meshes would rock !
(just thought I should mention it :) )
Post by CTZn » Thu May 14, 2009 9:14 am
Track vertices...
Hahahaha !!! So true...
:oops: :lol: :mrgreen: :wink: :roll:
handsomedave
Post by handsomedave » Fri May 15, 2009 12:43 am
WIP
Blender Fluid Sim
