This weekend Iam in Kitchen
Saving tree to '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/3216479110.tre'...
Failed to open file '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/3216479110.tre' for writing.
Indigo Renderer v1.1.17, Linux 32-bit Release build.
Using base Indigo directory path '/Indigo/Indigo.app/Contents/MacOS/../Resources/'.
Scene file path: '/Indigo/Example scenes/temp.xml'
Using working directory path '/Indigo/Example scenes'.
Loading Scene '/Indigo/Example scenes/temp.xml'...
Using linear tone mapping with scale=0.000500
SceneLoaderExcep: Failed to load texture '/Indigo/Example scenes/C:\programming\models/exr/uffizi-large.exr' (In element 'texture', around line 24, column 11): Error loading texture file '/Indigo/Example scenes/C:\programming\models/exr/uffizi-large.exr' - file not found
Using linear tone mapping with scale=0.000100
Loading external mesh 'prism' from path '/Indigo/Example scenes/prism/prism.3ds'...
Done.
WARNING: Using deprecated element 'diffuse'. (In element 'phong', around line 36, column 5)
(around line 51) WARNING: Overriding material definition for material 'prismmat'.
WARNING: Using deprecated element 'diffuse'. (In element 'phong', around line 53, column 5)
(around line 68) WARNING: Overriding material definition for material 'prismmat'.
WARNING: Using deprecated element 'diffuse'. (In element 'phong', around line 70, column 5)
WARNING: Using deprecated element 'colour'. (In element 'diffuse', around line 88, column 5)
Building Mesh 'prism'...
20 vertices (480 B)
8 triangles (224 B)
Couldn't find matching cached tree file, rebuilding tree...
Building kd-tree...
max tree depth: 62
total nodes used: 2 (16 B)
total leafgeom size: 8 (32 B)
Allocing intersect triangles...
intersect_tris mem usage: 384 B
Total tree mem usage: 432 B
Saving tree to '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/1635589313.tre'...
Failed to open file '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/1635589313.tre' for writing.
Done Building Mesh 'prism'. (Time taken: 0.00051 s)
Building Mesh 'groundmesh'...
4 vertices (96 B)
2 triangles (56 B)
Building kd-tree...
max tree depth: 62
total leafgeom size: 2 (8 B)
intersect_tris mem usage: 96 B
Total tree mem usage: 120 B
Saving tree to '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/3829043011.tre'...
Failed to open file '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/3829043011.tre' for writing.
Done Building Mesh 'groundmesh'. (Time taken: 0.00029 s)
Light luminous flux (geometry name=EnvSphereGeometry): 1.341E+11 lm
Building Object Tree...
6 objects.
calcing root AABB.
AABB: (-426.528229, -426.528229, -426.528229), (426.528229, 426.528229, 426.528229)
max tree depth: 7
reserving N nodes: 6(48 B)
total nodes used: 21 (168 B)
total leafgeom size: 23 (92 B)
Finished building tree.
Num buffer layers: 1
Master buffer size: 1.868 MB
Settings:
Frame upload period: 40.00000 s
Image save period: 10000000.00000 s
Splat filter: mn_cubic, blur=0.600000, ring=0.200000
Downsize filter: mn_cubic, blur=0.60000, ring=0.20000
Render region: false
Supersample factor: 2
Metropolis: false
Bidirectional: true
Hybrid: false
Ray origin nudge distance: 0.00010 m
Aperture diffraction: false
Post-process diffraction: true
Auto setting number of threads to 2.
Finished initialisation
Starting threads... (num threads: 2)
Starting render thread. (RNG seed=1)
Starting render thread. (RNG seed=2)
toneMapToLDRBuffer
toneMapToLDRBuffer done.
Using linear tone mapping with scale=0.000000
toneMapToLDRBuffer
toneMapToLDRBuffer
toneMapToLDRBuffer
toneMapToLDRBuffer
toneMapToLDRBuffer
Using linear tone mapping with scale=0.200000
WARNING: Using deprecated element 'albedo_spectrum'. (In element 'diffuse', around line 36, column 5)
WARNING: Using deprecated element 'albedo_spectrum'. (In element 'diffuse', around line 155, column 5)
23166 vertices (542.953 KB)
44123 triangles (1.178 MB)
Building kd-tree...
max tree depth: 62
0/32 nodes at depth 5 built.
1/32 nodes at depth 5 built.
2/32 nodes at depth 5 built.
3/32 nodes at depth 5 built.
4/32 nodes at depth 5 built.
5/32 nodes at depth 5 built.
6/32 nodes at depth 5 built.
7/32 nodes at depth 5 built.
8/32 nodes at depth 5 built.
9/32 nodes at depth 5 built.
10/32 nodes at depth 5 built.
11/32 nodes at depth 5 built.
12/32 nodes at depth 5 built.
13/32 nodes at depth 5 built.
14/32 nodes at depth 5 built.
15/32 nodes at depth 5 built.
16/32 nodes at depth 5 built.
17/32 nodes at depth 5 built.
18/32 nodes at depth 5 built.
19/32 nodes at depth 5 built.
20/32 nodes at depth 5 built.
21/32 nodes at depth 5 built.
22/32 nodes at depth 5 built.
23/32 nodes at depth 5 built.
24/32 nodes at depth 5 built.
25/32 nodes at depth 5 built.
26/32 nodes at depth 5 built.
27/32 nodes at depth 5 built.
28/32 nodes at depth 5 built.
total nodes used: 103861 (811.414 KB)
total leafgeom size: 71929 (280.973 KB)
intersect_tris mem usage: 2.020 MB
Total tree mem usage: 3.087 MB
Saving tree to '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/560771219.tre'...
Failed to open file '/Indigo/Indigo.app/Contents/MacOS/../Resources//tree_cache/560771219.tre' for writing.
Done Building Mesh 'groundmesh'. (Time taken: 0.62373 s)
Light luminous flux (geometry name=EnvSphereGeometry): 8.676E+21 lm
5 objects.
calcing root AABB.
AABB: (-157048528.000000, -157048528.000000, -157048528.000000), (157048528.000000, 157048528.000000, 157048528.000000)
max tree depth: 6
reserving N nodes: 5(40 B)
total nodes used: 13 (104 B)
total leafgeom size: 14 (56 B)
Settings:
Metropolis: false
Bidirectional: true
Hybrid: false
Using Reinhard tone mapping with pre_scale=1.000000, post_scale=1.000000, burn=10.000000
WARNING: Using deprecated element 'colour'. (In element 'diffuse', around line 30, column 5)
SceneLoaderExcep: MaterialExcep: ComplexIORExcep: ComplexIORDataSetExcep: Failed to open file '/Indigo/Indigo.app/Contents/MacOS/../Resources//nkdata/al.nk' for reading. (In element 'phong', around line 58, column 5)
