Indigo 1.1.15
Same on win32, log.txt is empty despite the logging tag. It's straight on the second line:
The file is created but left empty...
Executing 'indigo -o C:/work/3d/indigo/renders/marxD_notesTest.igs.png C:/work/3d/indigo/marxD_notesTest.igs'
WARNING: Failed to open log file at 'log.txt' for writing.
SSE present.
SSE2 present.
mateuszdraco
Re: win vs lin (both x64)
You were right, on my ubuntu i have only one thread. And i found where to chage itOnoSendai wrote:As dougal2 said, please check you are using the same number of threads in both tests. The speeds of the linux build and windows build should be pretty similar.
Display took 2,51314 s
Total render time elapsed: 5 m, 20 s
Done 34470000,00000 samples (71,81250 samples per pixel)
107685,06780 samples / second (9,28634 micro-seconds / sample)
As you can see there is no log.txt error and file isn't empty like on vista - it works. Also on ubuntu i don't have any SSE or SSE2 info, on vista it is for sure.Executing './indigo default.igs -t 1'
Using base Indigo directory path '.'.
Scene file path: 'default.igs'
Using working directory path ''.
Loading Scene 'default.igs'...
Finished initialisation
Starting threads... (num threads: 1)
Starting render thread. (RNG seed=1)
Grimm,Grimm wrote:Thanks eman,
I do have version 2.8, 2.8.9 to be exact. I did figure out one of my problems, getting the libwx_gtk2 libraries into /usr/lib64. I needed to add --libdir=/usr/lib64 to the configure command. The libraries are now built and in the right spot but now there is another problem.![]()
The libraries built from the source code are named like so:
The libraries Indigo wants are named:Code: Select all
libwx_base-2.8.so libwx_gtk2_core-2.8.so.0 libwx_gtk2_aui-2.8.so libwx_gtk2_core-2.8.so etc...
Notice the gtk2 vrs. gtk2u and the base vrs. baseu differences. Well, I thought, I can just link those names to my libraries. It didn't work.Code: Select all
libwx_gtk2u_aui-2.8.so.0 libwx_gtk2u_xrc-2.8.so.0 libwx_baseu_xml-2.8.so.0 etc...This is the current error I'm getting,
It looks like there is some difference with the libraries I compiled and the ones that Indigo expects. I searched the wxGTK web forum but didn't find anything about a WXU version. I also checked the configure file to see if there was an option but no luck. The saga continues.Code: Select all
./indigo ./indigo: /usr/lib64/libwx_baseu-2.8.so.0: version `WXU_2.8' not found (required by ./indigo) ./indigo: /usr/lib64/libwx_gtk2u_core-2.8.so.0: version `WXU_2.8' not found (required by ./indigo)
I can confirm these results. I tried pretty much the same thing, and am getting the same error:
./indigo
./indigo: /usr/lib64/libwx_gtk2u_core-2.8.so.0: version `WXU_2.8' not found (required by ./indigo)Thanks!
GNUdo wrote:
My OS is openSUSE 11.1 64bit.
SATtva_ wrote:Indigo not starting because it could not find libtiff.so.4: I had only libtiff.so.3 (couldn't upgrade to libtiff4), solution was to link libtiff.so.4 to libtiff.so.3
How this do it ? How create symlink libtiff.so.4 to libtiff.so.3.8.2 ?Indigo is linked with libtiff.so.4, however it is absent on my system (I have the latest version of media-libs/tiff present in the official portage tree installed). There is only libtiff.so.3 which is a symlink of libtiff.so.3.8.2. Creating a symlink libtiff.so.4 to libtiff.so.3.8.2 fixed the problem. Not really a Gentoo-way though.
lolko7, under root do:
ln -sv /usr/lib32/libtiff.so.3.8.2 /usr/lib32/libtiff.so.4
ln -sv /usr/lib64/libtiff.so.3.8.2 /usr/lib64/libtiff.so.4
- kikeonline
Re: Indigo 1.1.15
how can i make it work on Ubuntu 8.10!!
./indigo: error while loading shared libraries: libwx_gtk2u_aui-2.8.so.0: cannot open shared object file: No such file or directory
Re: Indigo 1.1.15
Make sure you have the latest version of wxGTK installed on your system. My version is 2.8.9.1.
- kikeonline
Re: Indigo 1.1.15
I compiled wtGTX-2.8.10 and still doesnt work :(
