Indigo 1.1.15
Psychotron80
Post by Psychotron80 » Thu Jan 08, 2009 9:49 am
I confirm too.
Post by CTZn » Thu Jan 08, 2009 8:33 pm
Same on win32, log.txt is empty despite the logging tag. It's straight on the second line:
Executing 'indigo -o C:/work/3d/indigo/renders/marxD_notesTest.igs.png C:/work/3d/indigo/marxD_notesTest.igs'
WARNING: Failed to open log file at 'log.txt' for writing.
SSE present.
SSE2 present.
The file is created but left empty...
SATtva_
Post by SATtva_ » Fri Jan 09, 2009 3:52 am
SSE present.
SSE2 present.
I don't have these lines on Linux amd64. ;)
mateuszdraco
Re: win vs lin (both x64)
Post by mateuszdraco » Fri Jan 09, 2009 8:17 am
OnoSendai wrote:As dougal2 said, please check you are using the same number of threads in both tests. The speeds of the linux build and windows build should be pretty similar.
You were right, on my ubuntu i have only one thread. And i found where to chage it ;) however vista is still faster ;)
Display took 2,51314 s
Total render time elapsed: 5 m, 20 s
Done 34470000,00000 samples (71,81250 samples per pixel)
107685,06780 samples / second (9,28634 micro-seconds / sample)
Executing './indigo default.igs -t 1'
Using base Indigo directory path '.'.
Scene file path: 'default.igs'
Using working directory path ''.
Loading Scene 'default.igs'...
Finished initialisation
Starting threads... (num threads: 1)
Starting render thread. (RNG seed=1)
As you can see there is no log.txt error and file isn't empty like on vista - it works. Also on ubuntu i don't have any SSE or SSE2 info, on vista it is for sure.
MSUdom5
Post by MSUdom5 » Tue Jan 27, 2009 1:49 pm
Grimm wrote:Thanks eman,
I do have version 2.8, 2.8.9 to be exact. I did figure out one of my problems, getting the libwx_gtk2 libraries into /usr/lib64. I needed to add --libdir=/usr/lib64 to the configure command. The libraries are now built and in the right spot but now there is another problem. :roll:
The libraries built from the source code are named like so:
libwx_base-2.8.so
libwx_gtk2_core-2.8.so.0
libwx_gtk2_aui-2.8.so
etc...
The libraries Indigo wants are named:
libwx_gtk2u_aui-2.8.so.0
libwx_gtk2u_xrc-2.8.so.0
libwx_baseu_xml-2.8.so.0
etc...
Notice the gtk2 vrs. gtk2u and the base vrs. baseu differences. Well, I thought, I can just link those names to my libraries. It didn't work. :( This is the current error I'm getting,
./indigo
./indigo: /usr/lib64/libwx_baseu-2.8.so.0: version `WXU_2.8' not found (required by ./indigo)
./indigo: /usr/lib64/libwx_gtk2u_core-2.8.so.0: version `WXU_2.8' not found (required by ./indigo)
It looks like there is some difference with the libraries I compiled and the ones that Indigo expects. I searched the wxGTK web forum but didn't find anything about a WXU version. I also checked the configure file to see if there was an option but no luck. The saga continues. :)
Grimm,
I can confirm these results. I tried pretty much the same thing, and am getting the same error:
./indigo
I am also running Fedora 9. I'd like to know what the 'u' means in "libwx_gtk2u_core-2.8.so.0". It's more than likely a build setting that needs to set at configuration. I'll continue to look into it. If anyone has any additional info, it would be greatly appreciated!
Post by OnoSendai » Tue Jan 27, 2009 2:21 pm
u = unicode, probably.
MSUdom5
Post by MSUdom5 » Tue Jan 27, 2009 2:24 pm
OnoSendai wrote:u = unicode, probably.
Ah! I'll try building with unicode support and post an update. Thanks Ono.
MSUdom5
Post by MSUdom5 » Tue Jan 27, 2009 3:15 pm
That was it! It works! Thanks Ono.
Grimm, use the --enable-unicode flag during for configure, and rebuild the libraries. The resulting libraries can then replace the old ones, and indigo should run fine.
Grimm
Post by Grimm » Wed Jan 28, 2009 8:54 pm
Excellent!! Thank you MSUdom5 and thank you Ono! That worked perfectly.
Grimm
MSUdom5
Post by MSUdom5 » Thu Jan 29, 2009 8:28 am
Make sure you keep the original libraries though as applications which need 2.4 support won't work (e.g. Audacity).
lolko7
Post by lolko7 » Wed Feb 18, 2009 1:07 am
GNUdo wrote:
Indigo not starting because it could not find libtiff.so.4: I had only libtiff.so.3 (couldn't upgrade to libtiff4), solution was to link libtiff.so.4 to libtiff.so.3
SATtva_ wrote:
Indigo is linked with libtiff.so.4, however it is absent on my system (I have the latest version of media-libs/tiff present in the official portage tree installed). There is only libtiff.so.3 which is a symlink of libtiff.so.3.8.2. Creating a symlink libtiff.so.4 to libtiff.so.3.8.2 fixed the problem. Not really a Gentoo-way though.
How this do it ? How create symlink libtiff.so.4 to libtiff.so.3.8.2 ?
My OS is openSUSE 11.1 64bit.
SATtva_
Post by SATtva_ » Wed Feb 18, 2009 4:59 am
lolko7, under root do:
ln -sv /usr/lib32/libtiff.so.3.8.2 /usr/lib32/libtiff.so.4
ln -sv /usr/lib64/libtiff.so.3.8.2 /usr/lib64/libtiff.so.4
kikeonline
Re: Indigo 1.1.15
Post by kikeonline » Sun Apr 19, 2009 4:29 am
how can i make it work on Ubuntu 8.10!!
./indigo: error while loading shared libraries: libwx_gtk2u_aui-2.8.so.0: cannot open shared object file: No such file or directory
SATtva_
Re: Indigo 1.1.15
Post by SATtva_ » Sun Apr 19, 2009 6:50 am
Make sure you have the latest version of wxGTK installed on your system. My version is 2.8.9.1.
kikeonline
Re: Indigo 1.1.15
Post by kikeonline » Sun Apr 19, 2009 4:26 pm
I compiled wtGTX-2.8.10 and still doesnt work :(
Users browsing this forum: No registered users and 91 guests
