My kitchen
My kitchen
Hi, this is my kitchen...
Bye
Delle
Bye
Delle
- Day version
- im1226930052_day.png (980.59 KiB) Viewed 18613 times
- Night version
- im1226930052_night.png (938.19 KiB) Viewed 18614 times
Hi Delle!
Interesting work! Congratulations!
I think the radiator area is really GREAT, and the cooking plane good enough.
I'd rather work a little more on the shaders of the furniture, it all seems no reflective at all, and that is not real..
The objects you used, instead, are really good!
Overall, a nice work for me!
I use default settings except these ones...
Bye
Delle
<renderer_settings>
<width>1280</width>
<height>960</height>
<aperture_diffraction>false</aperture_diffraction>
<post_process_diffraction>false</post_process_diffraction>
</renderer_settings>
Delle
Hey Delle, here just my 2 cent:
Do U use Exit Portals for the balcony? This should speed up the scene (less fireflies!)
The metal thing on the balcony seems to e an image with alpha map.... the white border isn't very nice, take care not to use step blend option if you alpha map is not pure black/white...
Did you used the render alpha foreground option of Indigo to get a mask for the sky? If not, give it a try, it renders super fast
No, if I use exit portals the terrace disappearDo U use Exit Portals for the balcony? This should speed up the scene (less fireflies!)
I've used the "Magic wand" tool of PSP 8 that's why there is the border...The metal thing on the balcony seems to e an image with alpha map.... the white border isn't very nice, take care not to use step blend option if you alpha map is not pure black/white...
Could you explain in detail?Did you used the render alpha foreground option of Indigo to get a mask for the sky? If not, give it a try, it renders super fast
P.S. Here is another version with the real background (Genoa - Italy)
Bye
Delle
- Cucina.jpg (586.19 KiB) Viewed 18319 times
He he.... nobody ever said that a Exit Portal has to be a simple 2D planeNo, if I use exit portals the terrace disappear![]()
Just make a box shaped Exit portal with no wall to your scene (normals facing inside!) so your terrace is stil infront of the Exit Portal!
Its slower than simple 2D plane, but should be still lot faster than without exit Portal!
just check out this link: http://www.indigorenderer.com/joomla/fo ... php?t=3479Could you explain in detail?
It causes a Crash to Indigo (v1.1.14)...just check out this link: http://www.indigorenderer.com/joomla/fo ... php?t=3479
Here is a simple scene that causes the crash (IndigoCrash.igs)...
If I eliminate the line...
<render_foreground_alpha>true</render_foreground_alpha>
Bye
Delle[/quote]
- IndigoCrash.igs
- (4.77 KiB) Downloaded 257 times
- CrashDialog.PNG (10.32 KiB) Viewed 18271 times
- im1227199955.png (618.93 KiB) Viewed 18271 times
