Indigo 1.1.8
Big Fan
Post by Big Fan » Sat Aug 09, 2008 2:54 pm
ono there seems to be an issue with 'phong' not liking 'albedo' for a texture
AFAIK all the other mat types accept 'albedo' and 'phong' is happy with the rest of the texture types, just not albedo :?
Edit: ok play time 95% done of 1.1.8 but not uv wraps stuff which I dont know enough about :oops:
attach is a very young and ugly render of glowing titanium (.nk) turbine...
Edit2: indeed why it is was more of a mess than intended was cos I didnt realise I had some bugs in there - squashed those now :wink: - here is a better render :P
still very cool layer stuff ono 8)
carbon
Post by carbon » Sat Aug 09, 2008 10:26 pm
hi ono, i still getting this error:
Error: IndigoDriverExcep: ObjectExcep: Tried to do a view-dependent subdivision on an instanced mesh. (subdivide_pixel_threshold > 0.0)
no subdivision anywhere in the scene.. in 1.1.7 was no problem..
Post by Zom-B » Sat Aug 09, 2008 10:37 pm
carbon wrote:hi ono, i still getting this error:
... and you always will keep getting this error, because the view depended subdivision doesn't work for instances! set it to 0 and your instances should work fine. Each instance of a mesh is positioned somewhere else in the 3D space so for each one the view depended subdivision should be calculated different....
carbon
Post by carbon » Sat Aug 09, 2008 11:59 pm
ZomB: would you tell me where to set it to 0?
Post by OnoSendai » Sun Aug 10, 2008 2:37 am
Big Fan wrote:hooray! thank you - a very useful post -peasants can be just adoreable sometimes :wink: no executions this week..dont expect promotion though :D
ok now here is my next question but useless ono can get off his butt and answer this one:
what happened to exponent maps?
there is no mention of these in the latest pdf
albedo, bump, displacement, emission...(exponent?)
Phong exponent is now a wavelength-independent material parameter. The manual is wrong on this one :)
Post by OnoSendai » Sun Aug 10, 2008 2:41 am
This is a bug that i'll fix for the next version.
Deus
Post by Deus » Sun Aug 10, 2008 2:56 am
How do we do a dirty work around? And what casuses the problem? I was just about to mess around with shaders but this kinda stopped me :)
carbon
Post by carbon » Sun Aug 10, 2008 3:28 am
so i removed instances and got this:
(Mac OS X 10.5.3 Wine 1.0, Xquartz 2.3.0, 4GB RAM, scene ~270MB)
Indigo Renderer v1.1.8, Windows 32-bit Release build.
SSE present.
SSE2 present.
SSE3 present.
Using base Indigo directory path ''.
Scene file path: '_toy/toy.igs'
Using working directory path '_toy'.
Loading Scene '_toy/toy.igs'...
extra_atmospheric: 0
sun_theta_rad: 0.89917
sun_solid_angle: 0.00006
Sky zenith luminance: 4476.42342 cdm^-2
Sun spectral radiance at 500nm: 17871244973397.33200 Wsr^-1m^-3
Processing included XML file '_toy\toy-mats.xml...
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'diffuse', around line 6, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 23, column 9)
Loading Complex IOR data from 'nkdata/al.nk'...
Calculating energy loss compensation curve for exponent 5500.000000
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 60, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 73, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 86, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 231, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'diffuse', around line 310, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 351, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'oren_nayar', around line 364, column 9)
WARNING: Using deprecated element 'albedo_spectrum'.  (In element 'diffuse', around line 393, column 9)
Processing included XML file '_toy\toy-meshs.xml...
wine: Unhandled exception 0x40000015 at address 0x7857bb47 (thread 001e), starting debugger...
wine(903) malloc: *** mmap(size=2097152) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
err:winedbg:dbg_active_attach Invalid event handle: 54
Picture 1.png (39.91 KiB) Viewed 13338 times
Post by Whaat » Sun Aug 10, 2008 4:14 am
I think there are some new shader bugs. I tried to use this shader from your 'shader tests' thread and I got an error saying that indigo could not find function 'eval'. :?
def eval(vec3 pos) real :
                     mul(
                        fbm(
                           mul(getTexCoords(0), 100.0),
                           10
                        0.001
I'll run some more tests later to see if this was an isolated case or if it happens every time.
Zorro is coming !
Post by CTZn » Sun Aug 10, 2008 4:17 am
Ok I think this is the moment for:
OnoSendai wrote:I'll release 1.1.8 tomorrow barring any unforeseen issues.
Post by fused » Sun Aug 10, 2008 5:00 am
OnoSendai wrote:Phong exponent is now a wavelength-independent material parameter. The manual is wrong on this one :)
:D i told you :P
Big Fan
Post by Big Fan » Sun Aug 10, 2008 8:16 am
@fused :mrgreen:
@whaat also have the same problem with that shader - dont know why - however ono said that example was broken -guess it still is the anist one seems ok though
