SkIndigo 1.0.4
strange thing is some files the previews work and others i get the message.
it seems to work all the time if i create a new file, but only a few of my existing ones.
i'll attach a .skp file that it won't work with and you can see if it works for you.
- cupboardtest.zip
- (111.28 KiB) Downloaded 340 times
Speechless
I am completely in awe of this new plug in. I am a maxwell user and I have been looking for a GUI in sketchup that compares with material editing in 3DS Max. Until now I had decided that this was impossible in SU.
This is extremely user friendly. Thanks!
Another great made in Canada Solution.
Re: Speechless
Thankyou so much! Spread the wordCreasia wrote:I am completely in awe of this new plug in. I am a maxwell user and I have been looking for a GUI in sketchup that compares with material editing in 3DS Max. Until now I had decided that this was impossible in SU.
And...greetings from Saskatoon! Welcome to Indigo!
Made in Canada
Hey Saskatoon,
How bout them Rough Riders. I am in Calgary.
I'll post the sweet car rendering that I am baking at work overnite. I set it up in about half an hour, thanks to the new interface.
Shaun
Shaun
cool..xrok1 wrote:hey guys i'm in edson, near jasper.
BTW, I responded to your problem already. Check your render settings and look at your thumbnail path. If the path is not valid, you will not be able to preview materials. The path is saved with your SU file so your old files are pointing to an old invalid path. Your new files are pointing to a valid path so they work. Make sense?
I am in the process of changing how this works so that there won't be any more of this confusion. Thumbnails will always be saved in the indigo folder (the path will no longer be saved with the SU file). This will prevent users from experiencing the problems you (and others) are having.
I work with Haworth, a large office furniture and modular architectural interiors company.
I also have my own business http://www.foresight3d.com
Here is a render that I put together in about 20 minutes thanks to the new interface.
render time is about 16 hours on a dual Xeon 3.4 (model from 3D warehouse by marian)
Small Tweek
Keeping in mind that you are still the guru, I did notice that I have multiple instances of the preset window coming up. If this is in Javascript, you could possibly remedy it by referencing the same window name each time it is called up.
I also wish that the indigo material preview render window came up smaller somehow.
Thanks for your dedication. You are working miracles!
Re: Small Tweek
I agreeCreasia wrote: I also wish that the indigo material preview render window came up smaller somehow.
