Here you go.
As always. The final result depends on scene scale.
- juice.igm
- (876 Bytes) Downloaded 413 times
- aleksandera
- aleksandera
This is a testrender of a glass I modeled recently.
I stopped it since I yust dont get what I want.
First of all I ghet no depth of filed.
I dont need no explenations, I just need a sample scene
of three simple cubes with blur on the first and the last one
If someone would be cind enough (please!!!), so I can
study it.
Tried to put suvakas yuice in it, but cant do this as well.
What exactly do I have to take care of while copying the
material data with a text editor?
I'm using Blender 2.45 and indigo_v1.0.4
Thanx for any help!
O, and how much is one BU (1m?)
study it.
Thanx for any help!
- im1198772749.png (869.88 KiB) Viewed 5443 times
Yes, 1BU = 1m, unless you have your "worldscale" set differently (Environment > Worldscale.) Incorrect scene scale will affect any DoF in your scene (though, I think I can see a bit in the glasses in the back...)
My rubik's cube scene had very heavy DoF... the cube itself was 3x3x3cm, and the F-stop (blendigo again) was at 32. Just guessing, I think you'd want to set your worldscale so that your glasses are about 20cm or so. (maybe a bit more)
Hope this helps...
(BTW, suv, extremely nice juice mat. As phr0st said, looks just like SunnyD...
Hope this helps...
- aleksandera
Hell yes!!! This is what I wanted:
[img][img]http://aycu05.webshots.com/image/38324/ ... 838_th.jpg[/img]
And all I had to do is to switch the aperture diffraction to generated.
Yet a litle bit to extreme I guess. Probably because the scene is only
half a meter large.
Still have no tuto on how to applay exising materials.
Regards
Aleksander[/img]
half a meter large.
Regards
Aleksander[/img]
apply existing materials???
Where do you set aperture diffraction to generated? O.o
half a meter isn't that small... simply use a higher f-stop in Blendigo...
You can convert Blender materials to Indigo mats, with using the "conv" button, but usually, you have to tweak the mats to get, what you want
- aleksandera
It's OK with the DOF now.
What I ment with applying existing materials is
like the yuice material in this thread.
So what do I do?
-disable the autorun button
-export
-open the IGS defoult file with Notepad
-find the colmun (material) with the name yuice
wich was named so deliberately, so I
can find and change it..........
I dont knowhow to do this,
something goes always wrong when
I start to render it.
Thanx so far!
So what do I do?
-export
Thanx so far!
