Space movie(Blender rendered)
- Neobloodline
I plan on rendering something cool in Indigo one day once I figure out animation clearly in blender...
I made this just for fun and to try out a couple of techniques I was reading about. My next movie will be longer and incorporate some of the compositing effects they've added lately to the cvs builds.
http://www.vimeo.com/411277
- Neobloodline
- Neobloodline
- Neobloodline
Well that was kinda the point of the exercise. I'm not sure how to use transparency maps etc. with Indigo... I used very complex shaders and texture layers to create the earth. Even though I probably didn't showcase it very well
I need to use higher resolution textures to I think to really make it like I envisioned it.
paulo_gomes
- Neobloodline
I was going to report that... also the Earth sphere res is too low at poles.that's a cool animation, but isn't the bump map of the moon 'negative'? there seams to be bubbles and not craters.
I think that's a good animation project for Indigo, it may render quick if you don't use too much transparency maps...
- Neobloodline
How do I go about using transparency mapping in Indigo? Kind of easy in Blender, you just load up your black/white transparency map and click the correct button
I have color maps, bump maps, specularity maps, transparency maps etc. that I have to figure out how to carry over to an indigo project. I'm going to put some time into it when I can get myself to stop playing Crysis.
My sphere meshes were pretty dense I thought. There are several spheres layered with different shaders, each of which are subdivided, I can't remember if I smoothed them or not though. Each of the subdivided spheres came from one original and was duplicated/resized. I don't really notice anything at the poles, but I'm guessing it's probably that my texture resolution for the moon is much nicer than the ones for the earth. If you look close and pause the animation of the earth you can kind of make out a separate layer around the cloud layer that disperses the backlight. I also have a layer that has very small emittance of lights that you can see on the dark side.
I tried to run a frame through Indigo and it says blah blah blah.. only 3 component jpegs are supported.
SmartDen already did such a render (not animated and in an earlier version, though) And yes, you can texturemap spheres
http://www.indigorenderer.com/joomla/in ... emId=20229
The stars are added in post process, the rest is pure Indigo
(The cloud-layer is one big alpha-mapped texture, the Sun poorly is missing, here...)
I guess, he still has the scene. Then, you'd only need to add the movement and wait, like... well... many hours per frame^^ (I think, that image backed 3 days, if I remember correctly, but I can't tell for sure, any more)
- Neobloodline
Yea, I've seen that image before and it's a nice attempt. Not to pick on it or anything but he's missing a lot of features that go into a believable earth like an atmosphere and different reflectance and effects of the water, ground and cloudcover. It may be hard to figure out how to add all these together with Indigo but I'm sure it can be done. Maybe not for a video though unless I can get a gigantic renderfarm to cook it or something.
Users browsing this forum: Google [Bot] and 48 guests
