Crash Indigo 0.8 stable
Alain
Post by Alain » Thu Aug 23, 2007 11:49 pm
Hello
I'm very new to Indigo and just followed the german basic tuturial for cindigo.
I installed the exporter 0.8.2 in cinema 4d 9.102.
I followed the instructions of the tutorial.
But if I load the exported igs- file into indigo 0.8 it crashes.
Here is the text of indigo monitor:
scene file path: 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_002.igs'
Using working directory path 'C:\Dokumente und Einstellungen\Administrator\Desktop'.
created world.
Loading Scene 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_002.igs'...
sun_theta_rad: 1.570796
sun_solid_angle: 0.000060
Sky zenith luminance (cd/m^2): 1988.199951
Sun spectral radiance (Wsr^-1m^-3) at 500nm: 1384112256.000000
Using Reinhard tone mapping with pre_scale=6.000000, post_scale=1.000000, burn=6.000000
loading external model 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_0020.obj'...
Found reference to material 'defaultMat'.
OBJ parse took 0.00299s
loaded model.
loading external model 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_0021.obj'...
OBJ parse took 0.00029s
loaded model.
loading external model 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_0022.obj'...
OBJ parse took 0.00175s
loaded model.
Building Mesh 'Cindigo_Test_0020'...
0 vertices (0B)
0 triangles (0B)
Couldn't find matching cached tree file, rebuilding tree...
TriTree::build()
calcing root AABB.
What have I done wrong ?
Regards
Alain
SmartDen
Post by SmartDen » Thu Aug 23, 2007 11:53 pm
You use wrong Indigo version ;) Use latest version!
I think your exporter is not compatible with indigo version you have installed. You better ask in Cinema sub-forum what are you doing wrong! Good luck!
BTW Welcome!
Alain
Post by Alain » Thu Aug 23, 2007 11:56 pm
I already tried with indigo v09 test6 but it crashed as well....
sciman
Post by sciman » Fri Aug 24, 2007 12:11 am
That seems to happen to me on my desktop computer. My laptop is fine though so it could have to do with ram amounts and cpu speeds. My 1gb ram 1.6 ghz dual core laptop runs indigo fine, while my 768mb ram 1.1ghz athlon xp desktop crashes on any indigo version above 0.8
Alain
Post by Alain » Fri Aug 24, 2007 12:17 am
I'm running it on a MacBookPro, 2Ghz Intel Core Duo, 1GB RAM, using Parallels to run Windows XP.
Does anybody have bad expireance with using it under Parallels ?
I could try it on Boot Camp.
Regards
Alain
Alain
Post by Alain » Fri Aug 24, 2007 12:18 am
I just saw that Parallels uses only 512MB RAM... that could be the reason, hold on I just try it ;-)
Post by Zom-B » Fri Aug 24, 2007 12:22 am
jep, could an RAM issue.
The Cindigo Exporter is still in a Beta status check here for a Buglist.
You'll maybe need to hand edit your exported igs a bit...
welcome to Indigo :)
++edit++
best to use latest cindigo and indigo versions!
CoolColJ
Post by CoolColJ » Fri Aug 24, 2007 12:24 am
I see you use C4D exporter
make sure all objects are editable - that always gets me
it crashes when it caches the mesh or rebuilds the tree as in your case
also check the layers of objects, it's better not to layer em upon export
Alain
Post by Alain » Fri Aug 24, 2007 12:37 am
@CoolColJ
What do you mean with "editable objects" ? You mean polygone objects in Cinema 4d ? Is it better to use polygone or parametric objects ?
and
What do you mean with "layer of objects" ? You mean the objects treestructure in cinema 4d ?
Regards
Alain
Post by fused » Fri Aug 24, 2007 12:49 am
this happens when you export objects wich are not editable or null-objects with an object tag.
thats a cindigo bug. will fix that
Alain
Post by Alain » Fri Aug 24, 2007 1:17 am
@fused
I made all objects editable and no null-objects have an object-tag (see screenshot below).
@sciman
tried it under Boot Camp (show me 0.98 GB RAM) an it didn't work as well.
Post by fused » Fri Aug 24, 2007 1:36 am
use plane instead of floor. it has to be a parametric plane, so not a polyonobecjt. dont use an objecttag.
will change that in the next version. its a relic from the beginning :)
Alain
Post by Alain » Fri Aug 24, 2007 2:49 am
@fused
does not work if I use a parametric plane without an object tag.
there comes another errormessage as you can see below.
what is "bidirectional" on a plane ? and what is a "finite area mesh" in cinema ?
can anyone translate that in german ? ;-)
I converted the plane in a polygonobject with an object tag an that worked.
Alain
Post by Alain » Fri Aug 24, 2007 2:57 am
@fused
will it be possible or is it already to test complex cinema scenes as you can see below with sub and subsub- objects ?
Regards
Älain
Post by Zom-B » Fri Aug 24, 2007 3:08 am
Alain wrote:@fused
finite is the oposit of infinite (endlich und unendlich)
Bi Dir is a render setting for Indigo it should speed up interior and Caustic renderings a bit (but it doesnt woork with an infinite floor!),
deactivate it if you really need an infinite floor using the indigo advanced settings in the Cindigo render tag.
btw: nice interrior!
