High Poly test
11 posts • Page 1 of 1
High Poly test
Post by OnoSendai » Sun Apr 15, 2007 8:54 pm
Just a little test render, using the bounding interval hierarchy tree type (BIH).
Model is from here: http://graphics.stanford.edu/data/3Dscanrep/
Each dragon has 7.2 million tris.
I'm using instancing to repeat the model.
Total Indigo mem usage is about 730MB.
Render time is ~20 mins
Post by suvakas » Sun Apr 15, 2007 9:24 pm
whoo...this is nice !!!
zuegs
Post by zuegs » Sun Apr 15, 2007 10:34 pm
Thats cool!!!
Just a small question: how you do instancing with changing materials? As i remember the material is assigned inside the <mesh>. Is there a way to override that inside the <object> (in case that mesh is declared in XML, not external 3ds-file) ???
Big Fan
Post by Big Fan » Sun Apr 15, 2007 10:55 pm
edited to remove all
Post by OnoSendai » Sun Apr 15, 2007 11:05 pm
Wow nice render Big Fan, blender internal is actually pretty good :)
Post by OnoSendai » Sun Apr 15, 2007 11:15 pm
zuegs wrote:Thats cool!!!
define stuff in this order:
mesh
material
model
material
model
material
model
mrCarnivore
Post by mrCarnivore » Mon Apr 16, 2007 8:38 pm
7.2 million tris? not bad in 20mins!
I guess when using sss, this render will take like 2 months or something... ;-)
IanT
Post by IanT » Mon Apr 23, 2007 10:58 am
Very nice Nick ... so how are you finding BIH vs. KD-Tree? I'm currently messing about with nested grids at the moment ... seems to outperform KD-Tree (but only just) but with about a fifth of the memory requirements.
(Sorry to go Off-topic :? )
Ian.
dogfin
Post by dogfin » Mon Apr 23, 2007 11:34 am
Just for fun I did some reading on both algorithms, but I couldn't find the answer to one thing. How well do they perform at the "teapot in a stadium" problem?
dogfin -
IanT
Post by IanT » Mon Apr 23, 2007 12:15 pm
dogfin wrote:Just for fun I did some reading on both algorithms, but I couldn't find the answer to one thing. How well do they perform at the "teapot in a stadium" problem?
dogfin -
They're both pretty effective, but the BIH will generally use significantly less memory than KD-Tree.
Ian.
Post by OnoSendai » Mon Apr 23, 2007 11:02 pm
IanT wrote:Very nice Nick ... so how are you finding BIH vs. KD-Tree? I'm currently messing about with nested grids at the moment ... seems to outperform KD-Tree (but only just) but with about a fifth of the memory requirements.
Ian.
BIHs are nice to work with. The build times are super fast, and the mem requirements are very low, so for large meshes, they are superior to kd-trees.
In terms of ray tracing performance, my BIH is getting about 30-90% of the kd-tree performance.
It's early days however, and I haven't made any careful measurements, just looking at the Mutations/s :)
If you're outperforming kdtrees with your nested grids, that's quite an achievement (unless your kd-tree implementation sux :) ).
I'm presuming your nested grids can cope with the teapot/stadium issue which plagues uniform grids?
