High Poly test
High Poly test
Just a little test render, using the bounding interval hierarchy tree type (BIH).
Model is from here: http://graphics.stanford.edu/data/3Dscanrep/
Each dragon has 7.2 million tris.
I'm using instancing to repeat the model.
Total Indigo mem usage is about 730MB.
Render time is ~20 mins
- dragons.png (495.3 KiB) Viewed 9960 times
define stuff in this order:zuegs wrote:Thats cool!!!
Just a small question: how you do instancing with changing materials? As i remember the material is assigned inside the <mesh>. Is there a way to override that inside the <object> (in case that mesh is declared in XML, not external 3ds-file) ???
mesh
material
model
material
model
material
model
mrCarnivore
BIHs are nice to work with. The build times are super fast, and the mem requirements are very low, so for large meshes, they are superior to kd-trees.IanT wrote:Very nice Nick ... so how are you finding BIH vs. KD-Tree? I'm currently messing about with nested grids at the moment ... seems to outperform KD-Tree (but only just) but with about a fifth of the memory requirements.
(Sorry to go Off-topic)
Ian.
In terms of ray tracing performance, my BIH is getting about 30-90% of the kd-tree performance.
It's early days however, and I haven't made any careful measurements, just looking at the Mutations/s
If you're outperforming kdtrees with your nested grids, that's quite an achievement (unless your kd-tree implementation sux
I'm presuming your nested grids can cope with the teapot/stadium issue which plagues uniform grids?
Users browsing this forum: Bing [Bot] and 12 guests
