Indigo Renderer 3.6.4 Beta Release
Re: Indigo Renderer 3.6.4 Beta Release
Post by Pibuz » Sat Jan 12, 2013 6:33 am
Yes. That, or something similar..
Post by Zom-B » Sat Jan 12, 2013 7:02 am
The Big benefit is already included alpha in the rendering is that DOF blurred areas in the BG are impossible to cut out using a alpha mask! Aperture Diffraction has the same problems...
Actually all the render passes stuff should be reworked I think.
Having them in separate Light Layers and calculated by usage of the running render process like recycling data.
Or at least one Layer rendermode where all passes get rendered at once (on Layers) if recycling of actual data is to "expensive" in performance or even not possible.
Post by zeitmeister » Sun Jan 13, 2013 1:14 am
+1 concerning the alpha "issue"...
Post by Zom-B » Tue Jan 15, 2013 4:02 am
Regarding the Foreground-Render a small bug:
FR doesn't work with ExitPortals. Would be nice if they would get ignored for that kind of renderings :)
Post by OnoSendai » Tue Jan 15, 2013 11:01 am
dag wrote:
OnoSendai wrote:
dag wrote:Spherical tiles ok now, but there's vertical lines that are brighter on both edges.
Better yet, can you send me the (simplified) scene?
Happens only with bidir.
(Hopefully) fixed now. Thanks for the neat testscene!
Post by Zom-B » Wed Jan 16, 2013 1:06 am
Here another Example of using the Foreground Alpha rendering in a real life scenario for background replacement, I scaled that example to 200%:
The base rendering:
Applied alpha foreground mask:
Example of background replacement:
You can see that white outline on the parsley :/
FakeShamus
Post by FakeShamus » Wed Jan 16, 2013 1:17 am
Zom-B wrote:You can see that white outline on the parsley :/
In this case you are trying to replace a very brightly lit background with a much darker one, though. There is bound to be some strong back-lit parsley edges there with your light set-up.
Post by Zom-B » Wed Jan 16, 2013 2:10 am
I was referring to the 1pixel edge around the parsley and not the overall contrast / brightness.
A such "extreme" example was only made to show the problem clearly!
Since no DOF Blur or Aperture Diffraction was set here the withe pixel border is rather because of alpha masking in PostPro...
Also a BIG benefit for alpha background directly in the renderer would be the the possibility to keep reflections on windows in interiors. Atm I have a technique to get them by disabling Sky in the LightLayers, but it simply isn't that great...
FakeShamus
Post by FakeShamus » Wed Jan 16, 2013 3:50 am
yes, totally. and I strongly support this idea of integrated alpha layer rendering, I was just pointing out that in most real-life situations it's not that big of an issue. you can make convincing composites using the alpha masks as-is.
but another thought is that it would actually be amazing if the layer + alpha concept could be extended to an individual object level, with the ability to render cut-outs of any part of your scene to its own layer for specific imaging needs.
Post by StompinTom » Wed Jan 16, 2013 12:36 pm
Zom-B wrote:Here another Example of using the Foreground Alpha rendering in a real life scenario for background replacement, I scaled that example to 200%:
The base rendering:
Quote for support! Separate alpha render is great, but fails on cases like these. Don't suppose there would be a way to extend that to glass materials / semi-transparent (phong + null blends) as well?
Post by OnoSendai » Thu Jan 17, 2013 1:43 am
Hi All,
The alpha rendering in Indigo could certainly do with an improvement. We'll try and get round to looking at that soon.
Post by Zom-B » Thu Jan 24, 2013 8:59 pm
OnoSendai wrote:The alpha rendering in Indigo could certainly do with an improvement. We'll try and get round to looking at that soon.
Hey Ono, I just have a project in my Pipeline that would benefit of improved alpha rendering.
No pushing at all, I'm just curious if there are plans to release here something soon, so I know if I need to figure out some workaround for that :)
Post by OnoSendai » Wed Jan 30, 2013 9:01 am
Hi All,
Just a note that we now have some preliminary support for alpha channels in the foreground render directly.
Post by StompinTom » Wed Jan 30, 2013 11:35 am
OnoSendai wrote:Hi All,
Great news!
Post by CTZn » Wed Jan 30, 2013 11:54 am
I'm curious about that !
Issue when loading back an IGM of a coating material: the substrate has no name and no type showing up, and Indigo will lost the reference to the node after the first material edit.
Same issue when loading back a double-sided material, win64.
Users browsing this forum: No registered users and 70 guests
