Indigo 0.7 test 4
Indigo 0.7 test 4
http://www2.indigorenderer.com/montecar ... _test4.zip
Changelog:
v0.7 test 4
* Added/finished decent OBJ support.
* fixed kd-tree caching
* messed round with mlt stuff, network rendering.
EDIT: I also fixed most (or all?) of the test scenes, so they should load without errors now (apart from missing meshes etc..).
EDIT: about the obj stuff:
Obj files now expose one uv-set, called 'default'.
multiple materials per obj file should work now.
Remember to turn off normal smoothing if there are no smoothing normals in the .obj file!
Changelog:
v0.7 test 4
whoo..next build !!
Can't wait to test the obj out.
Thanks Ono!!!
Suvakas
[edit:]
OBJ BitmapTexture - works
OBJ multimat - works
OBJ multimat using different BitmapTextures - works
Thanks Ono!!!
Suvakas
[edit:]
You can use any number of textures u want, it's just that they all have to use the same set of uv-coordinates, the 'default' set.suvakas wrote:whoo..next build !!
Thanks Ono!!!
Suvakas
[edit:]
OBJ BitmapTexture - works![]()
OBJ multimat using different BitmapTextures = nope
Does it mean that only one diffuse bitmaptexture can be used on one model?Obj files now expose one uv-set, called 'default'.
*.3ds has only one uv-set called 'albedo', but Multi-bitmap works there.
I don't see why different textures for different materials shouldn't work.
What happens when u try?
Yes, if normal_smoothing is true, the vertex normals in the .obj file are used.CTZn wrote:Does that mean that if true, normal smoothing is read from obj fileRemember to turn off normal smoothing if there are no smoothing normals in the .obj file!![]()
Thank youuuuu Onnnooooooo !!!
However, if there are no vertex normals in the .obj file, and normal_smoothing is true, bad things will happen
