Indigo 0.7 test 4
Indigo 0.7 test 4
Post by OnoSendai » Sat Feb 10, 2007 12:55 am
http://www2.indigorenderer.com/montecar ... _test4.zip
Changelog:
v0.7 test 4
* Added/finished decent OBJ support.
* fixed kd-tree caching
* messed round with mlt stuff, network rendering.
EDIT: I also fixed most (or all?) of the test scenes, so they should load without errors now (apart from missing meshes etc..).
EDIT: about the obj stuff:
Obj files now expose one uv-set, called 'default'.
multiple materials per obj file should work now.
Remember to turn off normal smoothing if there are no smoothing normals in the .obj file!
zuegs
Post by zuegs » Sat Feb 10, 2007 12:59 am
Thx Nick :D :D :D
Post by suvakas » Sat Feb 10, 2007 1:19 am
whoo..next build !!
Can't wait to test the obj out.
Thanks Ono!!!
Suvakas
[edit:]
OBJ BitmapTexture - works :)
OBJ multimat - works :)
OBJ multimat using different BitmapTextures - works :)
manitwo
Post by manitwo » Sat Feb 10, 2007 1:30 am
yeah ...
quick question ono: samples=mutations?
isabelp1
Post by isabelp1 » Sat Feb 10, 2007 1:31 am
and the blender's exporter?
it already exists ?
excuse me... :oops: i want try it
manitwo
Post by manitwo » Sat Feb 10, 2007 1:39 am
:shock: you are working on a hybrid-mode?
Post by OnoSendai » Sat Feb 10, 2007 1:58 am
suvakas wrote:whoo..next build !!
Thanks Ono!!!
Suvakas
[edit:]
OBJ multimat using different BitmapTextures = nope
Does it mean that only one diffuse bitmaptexture can be used on one model?
*.3ds has only one uv-set called 'albedo', but Multi-bitmap works there.
You can use any number of textures u want, it's just that they all have to use the same set of uv-coordinates, the 'default' set.
I don't see why different textures for different materials shouldn't work.
What happens when u try?
Post by OnoSendai » Sat Feb 10, 2007 2:00 am
manitwo wrote:yeah ...
Yes.
manitwo wrote::shock: you are working on a hybrid-mode?
My my.. you're observant aren't you? :P
Post by CTZn » Sat Feb 10, 2007 2:03 am
Does that mean that if true, normal smoothing is read from obj file :shock: :?: :D
Thank youuuuu Onnnooooooo !!!
manitwo
Post by manitwo » Sat Feb 10, 2007 2:04 am
yes :P
Post by OnoSendai » Sat Feb 10, 2007 2:05 am
Yes, if normal_smoothing is true, the vertex normals in the .obj file are used.
However, if there are no vertex normals in the .obj file, and normal_smoothing is true, bad things will happen :)
zsouthboy
Post by zsouthboy » Sat Feb 10, 2007 2:06 am
Yay! Now Indigo will get 60 MPG!
Post by CTZn » Sat Feb 10, 2007 2:08 am
Wow that thread is hot ;)
And a new doc, great !!!
tungee
thanx big master.
Post by tungee » Sat Feb 10, 2007 2:15 am
you are crazy man!
thanx!
Users browsing this forum: Bing [Bot] and 145 guests
