Motion Blur tests
For all Indigo users.
14 posts • Page 1 of 1
Motion Blur tests
Post by fused » Wed Apr 29, 2009 6:46 pm
more will follow.
Re: Motion Blur tests
Post by OnoSendai » Wed Apr 29, 2009 6:56 pm
Sweet.
I'll add mine while we're at it :)
SmartDen
Post by SmartDen » Wed Apr 29, 2009 8:35 pm
nice test. can you explain how to make it? is it described somewhere?
Check normals, dude!
Post by Zom-B » Wed Apr 29, 2009 8:47 pm
Looks like cindigo does export for Motion Blur now :mrgreen:
Post by fused » Wed Apr 29, 2009 9:20 pm
awesome ono, love that headbanging blue rabbit :)
Post by fused » Wed Apr 29, 2009 9:49 pm
ZomB wrote:Looks like cindigo does export for Motion Blur now :mrgreen:
veeeeeeeeeeeeeeeery experimental :mrgreen:
SmartDen wrote:nice test. can you explain how to make it? is it described somewhere?
i think i could mail you the examples i got from ono tonight.
carsten_fokuspunkt
Post by carsten_fokuspunkt » Fri May 01, 2009 3:51 am
these pictures look very very cool!!!!
cant wait for it.
@fused: is this 1 rendered frame of an animated object in cinema? should it be so easy :) how we can imagine the workflow of this feature?
its going straight forward now :)
cheers, carsten
Post by fused » Fri May 01, 2009 5:52 am
carsten_fokuspunkt wrote:@fused: is this 1 rendered frame of an animated object in cinema? should it be so easy :) how we can imagine the workflow of this feature?
cheers, carsten
yes, this is an animated object.
the workflow will look like this:
animate your scene, put a cindigo motion blur tag on objects that should be blurred (or on a null that contains the whole scene so every moving object will be blurred), choose the appropriate exposure to make the motion blur stronger / lighter, export, done.
Post by Zom-B » Fri May 01, 2009 7:34 am
yes, great stuff fused... as usual :lol:
Is it possible to use the native C4D motion Blur tags for control and setup?
Post by fused » Fri May 01, 2009 8:05 am
ZomB wrote:Is it possible to use the native C4D motion Blur tags for control and setup?
Basically yes. It would also be possible to take the strength parameter into account i think. But with this tag one cannot control the number of keyframes that should be exported, so it is more likely that i will build in a new tag. But i could still make c4ds tag work, with the fixed nummber of 2 keyframes exported.
Post by fused » Sat May 02, 2009 1:45 am
heres a test taht takes the exposure more or less correctly into consideration.
30 fps, exposure 0.3333, that means that 10 frames are taken into consideration for the motion blur.
:mrgreen:
SmartDen
Post by SmartDen » Sat May 02, 2009 1:53 am
it don't work here :(
Post by suvakas » Sat May 02, 2009 2:11 am
@Smart
Get the latest version - 2.0.4.
Motion blur is fixed there (the position bug, that made the model to dissapear..or whatever the bug was).
Post by OnoSendai » Sat May 02, 2009 12:40 pm
Nice test fused!
