veeeeeeeeeeeeeeeery experimentalZomB wrote:Looks like cindigo does export for Motion Blur now
i think i could mail you the examples i got from ono tonight.SmartDen wrote:nice test. can you explain how to make it? is it described somewhere?
yes, this is an animated object.carsten_fokuspunkt wrote:@fused: is this 1 rendered frame of an animated object in cinema? should it be so easyhow we can imagine the workflow of this feature?
its going straight forward now
cheers, carsten
Basically yes. It would also be possible to take the strength parameter into account i think. But with this tag one cannot control the number of keyframes that should be exported, so it is more likely that i will build in a new tag. But i could still make c4ds tag work, with the fixed nummber of 2 keyframes exported.ZomB wrote:Is it possible to use the native C4D motion Blur tags for control and setup?
