Texturing object with many VERTS
i got a prolem and cant find its solution,
I ve got object with applied subsurf so it have about 34000 Verts.
I have NO IDEA how to unwrap it for UV.
What moves You make in this kind of situation ?
Peace!
Peace!
ZBrush has a tool to "undo" applied subsurf and finally restitute the cage, the only other alternative I know apart redoing it is to delete the extra edge loops that were added by subsurf, that is, delete pretty much all edges.
I didn't make seams but you can try It's not so hard with a simple mesh
good work
good work
- exemple.blend.zip
- (39.57 KiB) Downloaded 278 times
