Texturing object with many VERTS
9 posts • Page 1 of 1
dembooed
Post by dembooed » Sun Mar 08, 2009 11:48 pm
i got a prolem and cant find its solution,
I ve got object with applied subsurf so it have about 34000 Verts.
I have NO IDEA how to unwrap it for UV.
What moves You make in this kind of situation ?
Peace!
Jambert
Post by Jambert » Sun Mar 08, 2009 11:57 pm
Maybe retopology, do you have a screenshot?
dembooed
Post by dembooed » Mon Mar 09, 2009 12:05 am
Jambert
Post by Jambert » Mon Mar 09, 2009 12:17 am
I would model it again, using subsurf without applying it. I try to do it and I share the file :wink:
dembooed
Post by dembooed » Mon Mar 09, 2009 12:20 am
nice, thx
alex22
Post by alex22 » Mon Mar 09, 2009 12:23 am
As you have a simple model, you could use alt+click to select a loop of vertice, then make seams (ctrl+e) for uv and then unwrap.
Post by CTZn » Mon Mar 09, 2009 12:44 am
ZBrush has a tool to "undo" applied subsurf and finally restitute the cage, the only other alternative I know apart redoing it is to delete the extra edge loops that were added by subsurf, that is, delete pretty much all edges.
Jambert
Post by Jambert » Mon Mar 09, 2009 12:44 am
I didn't make seams but you can try It's not so hard with a simple mesh :wink:
good work
exemple.blend.zip
(39.57 KiB) Downloaded 278 times
dembooed
Post by dembooed » Mon Mar 09, 2009 3:24 am
ok, thx :)
Users browsing this forum: Bing [Bot] and 22 guests
