skin shader
skin shader
Post by neo0. » Fri Jul 04, 2008 7:34 am
What are soom good parameters?
aleksandera
Post by aleksandera » Fri Jul 04, 2008 11:43 am
You optimist!
There aren't any.
I did some three hundert tests and I have some thousand to go.
You simply have to know what you want.
Visit the adult channel !
:twisted:
OMG nudity!.jpg (366.84 KiB) Viewed 16450 times
Post by Borgleader » Fri Jul 04, 2008 12:23 pm
lol @ visit the adult channel.
zsouthboy
Post by zsouthboy » Fri Jul 04, 2008 12:26 pm
@aleksandera:
:shock: that looks fantastic! the skin looks so real!
Post by neo0. » Fri Jul 04, 2008 12:47 pm
Sooo.. Parameters?
SOmethign basic maybe? WHat should I set SSS to for example?
Post by Borgleader » Fri Jul 04, 2008 12:54 pm
neo0. wrote:Sooo.. Parameters?
Tests tests and more tests! :P
Post by neo0. » Fri Jul 04, 2008 1:25 pm
What type of material should I pick atleast? Glossy transparent?
Post by Borgleader » Fri Jul 04, 2008 1:28 pm
neo0. wrote:What type of material should I pick atleast? Glossy transparent?
I searched the forum, and someone was using a phong shader for his. if thats of any help.
Post by neo0. » Fri Jul 04, 2008 1:28 pm
OK, thanks.
Post by CTZn » Fri Jul 04, 2008 1:32 pm
Seriously neO, OnoSendai implemented two mediums specificaly for skin simulation: dermis and epidermis; they are documented.
Post by Borgleader » Fri Jul 04, 2008 1:42 pm
CTZn wrote:Seriously neO, OnoSendai implemented two mediums specificaly for skin simulation: dermis and epidermis; they are documented.
The only way I got them to work is if I used a blend material, composed of a a diffuse mat (skin color) + phong with epidermis medium. because alone all i get are black previews :(
EDIT: I'm running a bunch of tests now. Good thing it renders rather quickly. If I run into anything good. I'll post stuff. Skin shading seems to be quite complex, but yet it intrigues me, and I love complexity. So anyway, I'll probably be running tests for a few days. If I end up with multiple conclusive results might create some sort of wiki page with settings for good skin shaders and such. Anyway...it's too early to say.
Post by Zom-B » Fri Jul 04, 2008 2:56 pm
... and slow like a snail on Valium :?
take a look here...
Post by neo0. » Fri Jul 04, 2008 3:32 pm
Well im on sketchup and I cant see any material types called dermis.
Post by fused » Fri Jul 04, 2008 4:25 pm
Borgleader wrote:The only way I got them to work is if I used a blend material, composed of a a diffuse mat (skin color) + phong with epidermis medium.
:shock: :?
manitwo
Post by manitwo » Fri Jul 04, 2008 5:23 pm
resembles a plucked chicken somehow, no? :D
