indigo.exe not a valid win32 app
8 posts • Page 1 of 1
jmlima
Post by jmlima » Mon Apr 07, 2008 10:01 am
Guys,
Firstly , hello to everyone!
Now, a small hick-up. I just installed the Sketch-up exporter, and the Indigo renderer, when I press the render button in Sketch-up, the DOS boxes open, and hen I get an '<path>/indigo.exe is a valid win32 application' dialog box...
Any suggestions / ideas / fixes?
Thanks in advance.
jmlima
Post by jmlima » Tue Apr 08, 2008 12:22 am
just found the answer... the latest version of the rendere is not the one you're supposed to use with sketchup...
not very clear in the download areas...
misandee
Re: indigo.exe not a valid win32 app
Post by misandee » Fri May 15, 2009 5:30 pm
hi.. i got the same problem now.. can you tell me how to fix it?
this is what ive done:
1. download the indigo_x64_v1.0.9_2 and skindigo for sketchup and put the indigo folder in the program files
2 i followed the instruction written to put the .rb in the plugins and skindigo folder in the plugins..and supreviews in the indigo folder
3 i run the skethup and locate to the indigo.exe in the indigo_x64_v1.0.9_2 folder
4. everytime i try to click render the DOS and thaht message appeared..
i've tried to download IndigoRenderer_x64_2.0.6_Setup and did the same things as above..
but it still failed..
and i've tried to use sketchup 6 and 7 too..
what i have to do now?
remus
Post by remus » Fri May 15, 2009 6:50 pm
Which version of skindigo did you download?
Post by fused » Fri May 15, 2009 7:21 pm
if you dont have a 64 bit os you should not download the 64 bit version of indigo... try the 2.0.6 version without x64 in its name.
misandee
Post by misandee » Fri May 15, 2009 7:41 pm
ive downloaded the IndigoRenderer_x64_2.0.6_Setup and indigo_x64_v1.0.9_2
i tried both.... oh should i try the 32 bit?
Post by suvakas » Fri May 15, 2009 7:51 pm
If you have 32bit Windows, then you can only use 32 bit applications.
So yes, try with 32bit Indigo.
misandee
Post by misandee » Tue May 19, 2009 2:22 pm
ok i did it..thx
Users browsing this forum: No registered users and 93 guests
