Guys,
Firstly , hello to everyone!
Now, a small hick-up. I just installed the Sketch-up exporter, and the Indigo renderer, when I press the render button in Sketch-up, the DOS boxes open, and hen I get an '<path>/indigo.exe is a valid win32 application' dialog box...
Any suggestions / ideas / fixes?
Thanks in advance.
indigo.exe not a valid win32 app
Re: indigo.exe not a valid win32 app
hi.. i got the same problem now.. can you tell me how to fix it?
this is what ive done:
1. download the indigo_x64_v1.0.9_2 and skindigo for sketchup and put the indigo folder in the program files
2 i followed the instruction written to put the .rb in the plugins and skindigo folder in the plugins..and supreviews in the indigo folder
3 i run the skethup and locate to the indigo.exe in the indigo_x64_v1.0.9_2 folder
4. everytime i try to click render the DOS and thaht message appeared..
i've tried to download IndigoRenderer_x64_2.0.6_Setup and did the same things as above..
but it still failed..
and i've tried to use sketchup 6 and 7 too..
what i have to do now?
Which version of skindigo did you download?
if you dont have a 64 bit os you should not download the 64 bit version of indigo... try the 2.0.6 version without x64 in its name.
ive downloaded the IndigoRenderer_x64_2.0.6_Setup and indigo_x64_v1.0.9_2
i tried both.... oh should i try the 32 bit?
If you have 32bit Windows, then you can only use 32 bit applications.
So yes, try with 32bit Indigo.
ok i did it..thx
Users browsing this forum: No registered users and 110 guests
