oh no ! more experiments !
drBouvierLeduc
Post by drBouvierLeduc » Wed Aug 08, 2007 10:29 am
As every thread seems to be dealing with tests lately, I give it a go.
I'm not testing indigo's latest kick ass features, but rather playing with shaders and indigo's infinite possibilities in that domain.
So I'm not heading anywhere in particular, just a bit of fun (and learning) with blended materials, sss, exponent maps etc...
Hopefully all this will made some proper scene in the end.
So here are a small bunch of images.
Just a note on the leaves : I used the same technique as explained here (at the bottom).
I got something, but if think the sss values can be improved (or is it the model who need some tweaking ?... dunno. If I had more vertices to the model (150k !), I think my computer will explode).
Well, ok, nothing fancy, just a teapot.
the same leaf viewed from bottom. Hurray ! When lite from behind, you can see the leaf's translucency. I Made billions of tries before I got correct translucency. (although it looks a bit too much like gelatin)
"sss-ized" leaves of bamboo. They are made of two blended materials : textured phong and green sss. Although this is kind of biased, it looks ok.
a blend of 5 materials.
Close up on the balls. Here I tested bump maps on simple spheres.
balls, balls, balls (please don't focus on the ground, just an early try).
Post by Kram1032 » Wed Aug 08, 2007 10:37 am
damn, you got a "chlorophyll" mat!
carbon
Post by carbon » Wed Aug 08, 2007 10:51 am
oh yes! really amazing!
walter
Post by walter » Wed Aug 08, 2007 10:52 am
Beautiful!
Is that a mate I see in the first pic ?!
test-balls3.jpg looks especially nice. I like the effect you created with the blends...
Regarding test-bamboo2.jpg .. I'm not sure I've ever actually been able to see through a leaf like that :P but its probably hard to get that balanced with the right SSS (which looks great, btw).
Olis
Post by Olis » Wed Aug 08, 2007 10:52 am
Beautiful test renders!
Re: oh no ! more experiments !
Post by Zom-B » Wed Aug 08, 2007 11:02 am
As Usual some really nice scenes from you Doc :)
drBouvierLeduc wrote:the same leaf viewed from bottom. Hurray ! When lite from behind, you can see the leaf's translucency. I Made billions of tries before I got correct translucency. (although it looks a bit too much like gelatin)
You have to give your mesh some volume, otherwise there is no scattering inside the leaf, because there is no "inside" ^^
Otherwise you could try using a glossy Transparent Material, instead of specular this should enhance the result drastically!
Post by Kram1032 » Wed Aug 08, 2007 11:29 am
in that case, it would be black, anyway, wouldn't it?
Although....
Argh... Not shure, anymore, about that.
CoolColJ
Post by CoolColJ » Wed Aug 08, 2007 11:46 am
very nice renders!
matt
Post by matt » Wed Aug 08, 2007 1:14 pm
Can you give us the specifics on the SSS settings for the leaves and a general idea of how thick you made them? It's looking good. Wouldn't it be faster to get that effect with a diffuse transmitter and a single sided leaf? I thought that was one of the things diffuse transmitters were made for.
Post by OnoSendai » Wed Aug 08, 2007 5:27 pm
Stunning materials as per usual Dr.
Can you go into a little more detail on the leaf material?
It uses a diffuse transmitter / phong blend, right?
Would you consider writing a tutorial on the leaf material, or even just post the material to the forums. A high quality leaf material (or guide on how to make one) is something Indigo users need.
matsta
Post by matsta » Wed Aug 08, 2007 5:30 pm
simply amazing. some awesome renders. keep it up!
greetz
mat
Post by suvakas » Wed Aug 08, 2007 6:58 pm
Very, very good tests !!
I specially like the sun + plant composition.
Leaf material is also great too.
Stur
Post by Stur » Wed Aug 08, 2007 8:18 pm
As usual, your tests look like finished masterpieces, it's so frustrating for common mortals like us ... But please, send more !
Now that you prooved you are the materials master here, you HAVE to post some tutorials :P
Post by BbB » Wed Aug 08, 2007 8:23 pm
Docteur, you send my jaw dropping every time.
One small footnote, thought, I second other comments about it being actually unlikely that you could see through a bamboo leaf. I would also try a diffuse transmitte instead of SSS. It may or may not look better, but at the very least it will clear considerably faster. Anyway, just my two cents as a noob.
Post by OnoSendai » Wed Aug 08, 2007 8:28 pm
Yeah, you can't usually see through leaves like that.
To put it another way, any light that makes it through the leaf will be scattered at least once.
