oh no ! more experiments !
drBouvierLeduc
Post by drBouvierLeduc » Wed Aug 08, 2007 10:29 am
As every thread seems to be dealing with tests lately, I give it a go.
I'm not testing indigo's latest kick ass features, but rather playing with shaders and indigo's infinite possibilities in that domain.
So I'm not heading anywhere in particular, just a bit of fun (and learning) with blended materials, sss, exponent maps etc...
Hopefully all this will made some proper scene in the end.
So here are a small bunch of images.
Just a note on the leaves : I used the same technique as explained here (at the bottom).
I got something, but if think the sss values can be improved (or is it the model who need some tweaking ?... dunno. If I had more vertices to the model (150k !), I think my computer will explode).
Well, ok, nothing fancy, just a teapot.
the same leaf viewed from bottom. Hurray ! When lite from behind, you can see the leaf's translucency. I Made billions of tries before I got correct translucency. (although it looks a bit too much like gelatin)
"sss-ized" leaves of bamboo. They are made of two blended materials : textured phong and green sss. Although this is kind of biased, it looks ok.
a blend of 5 materials.
Close up on the balls. Here I tested bump maps on simple spheres.
balls, balls, balls (please don't focus on the ground, just an early try).
Post by Kram1032 » Wed Aug 08, 2007 10:37 am
damn, you got a "chlorophyll" mat!
carbon
Post by carbon » Wed Aug 08, 2007 10:51 am
oh yes! really amazing!
walter
Post by walter » Wed Aug 08, 2007 10:52 am
Beautiful!
Is that a mate I see in the first pic ?!
test-balls3.jpg looks especially nice. I like the effect you created with the blends...
Regarding test-bamboo2.jpg .. I'm not sure I've ever actually been able to see through a leaf like that :P but its probably hard to get that balanced with the right SSS (which looks great, btw).
Olis
Post by Olis » Wed Aug 08, 2007 10:52 am
Beautiful test renders!
Re: oh no ! more experiments !
Post by Zom-B » Wed Aug 08, 2007 11:02 am
As Usual some really nice scenes from you Doc :)
drBouvierLeduc wrote:the same leaf viewed from bottom. Hurray ! When lite from behind, you can see the leaf's translucency. I Made billions of tries before I got correct translucency. (although it looks a bit too much like gelatin)
You have to give your mesh some volume, otherwise there is no scattering inside the leaf, because there is no "inside" ^^
Otherwise you could try using a glossy Transparent Material, instead of specular this should enhance the result drastically!
Post by Kram1032 » Wed Aug 08, 2007 11:29 am
in that case, it would be black, anyway, wouldn't it?
Although....
Argh... Not shure, anymore, about that.
CoolColJ
Post by CoolColJ » Wed Aug 08, 2007 11:46 am
very nice renders!
matt
Post by matt » Wed Aug 08, 2007 1:14 pm
Can you give us the specifics on the SSS settings for the leaves and a general idea of how thick you made them? It's looking good. Wouldn't it be faster to get that effect with a diffuse transmitter and a single sided leaf? I thought that was one of the things diffuse transmitters were made for.
Post by OnoSendai » Wed Aug 08, 2007 5:27 pm
Stunning materials as per usual Dr.
Can you go into a little more detail on the leaf material?
It uses a diffuse transmitter / phong blend, right?
Would you consider writing a tutorial on the leaf material, or even just post the material to the forums. A high quality leaf material (or guide on how to make one) is something Indigo users need.
matsta
Post by matsta » Wed Aug 08, 2007 5:30 pm
simply amazing. some awesome renders. keep it up!
greetz
mat
Post by suvakas » Wed Aug 08, 2007 6:58 pm
Very, very good tests !!
I specially like the sun + plant composition.
Leaf material is also great too.
Stur
Post by Stur » Wed Aug 08, 2007 8:18 pm
As usual, your tests look like finished masterpieces, it's so frustrating for common mortals like us ... But please, send more !
Now that you prooved you are the materials master here, you HAVE to post some tutorials :P
Post by BbB » Wed Aug 08, 2007 8:23 pm
Docteur, you send my jaw dropping every time.
One small footnote, thought, I second other comments about it being actually unlikely that you could see through a bamboo leaf. I would also try a diffuse transmitte instead of SSS. It may or may not look better, but at the very least it will clear considerably faster. Anyway, just my two cents as a noob.
Post by OnoSendai » Wed Aug 08, 2007 8:28 pm
Yeah, you can't usually see through leaves like that.
To put it another way, any light that makes it through the leaf will be scattered at least once.
Users browsing this forum: No registered users and 178 guests
