a big trouble or bug (help me please!)
first, I don't speak English.
I like indigo ,it's very science . the effect is so real ,and it's free soft.
I useing 3dsmax 8 or 9 ,indigo 0.8 ,and maxigo 0.8b.
simple scense : no error
but
big scense :"SceneLoaderExcep:failed to load XML -doc from path,Exported-from-max/kekkek.max/kskksk.max-scene.igs/:Error reading and tag.Line 74 column5" always
it's for what ??
what i can do?
think you !
but
it's for what ??
what i can do?
think you !
scene directory is indigo maked.
my max scene file is Exported_From_Max.zip
- Exported_From_Max.zip
- (3.81 MiB) Downloaded 299 times
another file
is 3dsmax9 maked menlian.max
and
indigo maked file
they are homologous .
think you
and
indigo maked file
think you
- menlian.max.rar
- (15.43 KiB) Downloaded 315 times
I checked the menlian.max scene. The problem is, that you are exporting into OBJ format, but you have models in your scene, that don't have material applied. When exporting to OBJ all the models must have material. Otherwize Indigo will give you and error message.
Please check the Maxigo's readme file. Models without material will only render fine when using XML format. Exporting to 3ds format renders them red.
About your other scenes... You have some funky model names there. I think Indigo don't know how to read those. So please check your naming.
Here's the menlian.max exported to XML and a screenshot of those strange names:
- strange_obj_names.png (673 Bytes) Viewed 10511 times
- exported to XML
- menlian.jpg (44.46 KiB) Viewed 10512 times
first
because just now touch indigo ,so have a little mind ,hope you don't dislike me
materials :
emitter:if add "image" to "emitter type" , useing image make lighting. likeness TV
phong: if add direction for glossiness is OK or NO OK , and if useing image control the fresnel is OK or NO OK.
materials :
- bb.jpg (107.66 KiB) Viewed 10427 times
