problem with focus (camera) ?
10 posts • Page 1 of 1
Zalevskiy
Re: problem with focus (camera) ?
Post by Zalevskiy » Sat Aug 31, 2019 11:05 pm
try converting the scene format from mm to cm
or scale all scene objects x10/x100%
also can change camera f-stop 32 | 64
for indigo anti-blurring helps to render the image in 2000px + resolution and reduce the resolution to 1000px which gives sharpness to the image
Post by pixie » Sun Sep 01, 2019 10:01 am
you can try picking the focus manually
Post by pixie » Sun Sep 01, 2019 12:12 pm
I forgot my render for 2hours, it was running on 2700k and got about 22k samples, I then went on rendering with a rtx 2070 , roughly 3 minutes
sger
Post by sger » Mon Sep 02, 2019 6:34 am
settings:
http://www.archery-3d.art/#gallery-39
with tag on gem:
http://www.archery-3d.art/#gallery-37
without:
http://www.archery-3d.art/#gallery-38
import: scale x2 in mm ( in cm mesh too big)
00111.zip
(1.04 MiB) Downloaded 554 times
sger
Post by sger » Mon Sep 02, 2019 6:45 am
i will try but not finded this settings yet
sger
Post by sger » Mon Sep 02, 2019 6:56 am
try converting the scene format from mm to cm - big mesh
1 - big mesh
2 - I scale x2
3 - no effect
4 - I will try with bigger comp
Post by pixie » Mon Sep 02, 2019 8:19 am
With higher f-stop in pt
sger
Post by sger » Mon Sep 02, 2019 3:49 pm
great!
is it there:
http://www.archery-3d.art/#gallery-35 ?
i try c4d little :(
Post by pixie » Tue Sep 03, 2019 1:37 am
well, bidir would be better for the gem, since pt doesn't do as well dispersion.
