problem with focus (camera) ?
Re: problem with focus (camera) ?
try converting the scene format from mm to cm
or scale all scene objects x10/x100%
also can change camera f-stop 32 | 64
for indigo anti-blurring helps to render the image in 2000px + resolution and reduce the resolution to 1000px which gives sharpness to the image
- pixie
you can try picking the focus manually
						- pixie
I forgot my render for 2hours, it was running on 2700k and got about 22k samples, I then went on rendering with a rtx 2070 , roughly 3 minutes
settings:
http://www.archery-3d.art/#gallery-39
with tag on gem:
http://www.archery-3d.art/#gallery-37
without:
http://www.archery-3d.art/#gallery-38
import: scale x2 in mm ( in cm mesh too big)
with tag on gem:
without:
				- 00111.zip
- (1.04 MiB) Downloaded 405 times
1 - big meshZalevskiy wrote: ↑Sat Aug 31, 2019 11:05 pm
try converting the scene format from mm to cm - big mesh
2 - I scale x2
3 - no effect
4 - I will try with bigger comp
- pixie
well, bidir would be better for the gem, since pt doesn't do as well dispersion.
