ibalouka
by ibalouka » Sat Nov 04, 2006 3:38 am
i know.....
this is why i asked....
so i guess i did somthing wrong instaling the M2I....
it's a bit strange, cause i can see the glass mat. but not the metal nk.
shuold the nk folder be some other place then inside the indigo's folder?
i'll try it later at home.
thanks a lot afecelis,
cheers
afecelis
by afecelis » Sat Nov 04, 2006 4:03 am
Installing M2I is just a matter of copying the proper scripts in the corresponding folders so I don think that's the problem. I'm using Max6 and it's working fine there, so if you're having probs with Max9 32 bits then it's something that definitely changed
ibalouka
by ibalouka » Sat Nov 04, 2006 4:10 am
wll, i'll try right away with max 7 and let u know...
thanks
Kosmokrator
by Kosmokrator » Sat Nov 04, 2006 4:22 am
im using max 7 and M2I work perfect....maybe something change in 8 or 9 version i dont know....anyone tester??
ibalouka
by ibalouka » Sat Nov 04, 2006 4:39 am
well, last night i tried with max9 32bit , worked just fine.
(a part the metal thing)
i just installed indigo her in studio, on max 7 the same problem.
i can't see the nk metal mat. from the material editor....
100% it's my stupidity...
should i copy the nkdata. folder to some wherelse or leave it in
the indigo dir.??
thanks for the help,
afecelis
by afecelis » Sat Nov 04, 2006 4:55 am
no, not at all.
Check your m2i.ini file; this sets the path to Indigo which should be:
indigodir=C:\Indigo
or modify it according to where you installed indigo
ibalouka
by ibalouka » Sat Nov 04, 2006 8:14 am
afecelis wrote:no, not at all.
indigodir=C:\Indigo
that was it. 1000 thanks
afecelis
by afecelis » Sat Nov 04, 2006 8:35 am
u3dreal
by u3dreal » Sat Nov 04, 2006 9:45 am
He he
Thanks afecelis for helping me out...!!
Well man will test before they go RTFM...
cheers
have fun with the exporter and let me know when it works ... or when it don't ...
cheers
u3dreal
u3dreal
by u3dreal » Sat Nov 04, 2006 9:48 am
psor wrote:Sorry Gregor, I had no spare time to fully check it. I did a quick test
and I was wrong. The error occurs when I hit render in the M2I panel.
Then I do get an information that tells me something like:
"Unknown faceted blahblah..." I'll check it later today and write
it down ... ;o)
btw. it was the 32bit version that I tried Indigo on, not the 64bit as
I stated bevor, sorry ...
take care
Oleg
Hi Oleg ... i guess there is a wrong material in your scene ... that's usually what i get when using
k-material ...
check it but i'm pretty certain.... i really should go think about adding
an error message here..or maybe a report at the end.
cheers
u3dreal
u3dreal
by u3dreal » Sat Nov 04, 2006 12:19 pm
Progress ...
I'm happy as a child ... finally i found out how to get the right upvector for the camera..
He he .. so for most of you this might look like a pretty ugly rendering but at a closer look
Finally we can make pics with cameraroll !!
been trying this since february..
Let's see where this all end up ...
cheers
u3dreal
afecelis
by afecelis » Sat Nov 04, 2006 12:32 pm
speechless!
Since February? man! you have beaten the challenge!
great work! errm... what's it for?
Kosmokrator
by Kosmokrator » Sun Nov 05, 2006 2:48 am
u3dreal
by u3dreal » Sun Nov 05, 2006 3:36 am
Well i have to leave now so maybe tomorrow..
cheers
u3dreal
