max 2 indigo 0.615 beta2 - update
ibalouka
Post by ibalouka » Sat Nov 04, 2006 3:38 am
i know..... :wink: this is why i asked....
so i guess i did somthing wrong instaling the M2I.... :cry:
it's a bit strange, cause i can see the glass mat. but not the metal nk.
shuold the nk folder be some other place then inside the indigo's folder?
i'll try it later at home.
thanks a lot afecelis,
cheers
afecelis
Post by afecelis » Sat Nov 04, 2006 4:03 am
Installing M2I is just a matter of copying the proper scripts in the corresponding folders so I don think that's the problem. I'm using Max6 and it's working fine there, so if you're having probs with Max9 32 bits then it's something that definitely changed :wink:
ibalouka
Post by ibalouka » Sat Nov 04, 2006 4:10 am
wll, i'll try right away with max 7 and let u know... :wink:
thanks
Kosmokrator
Post by Kosmokrator » Sat Nov 04, 2006 4:22 am
:roll: im using max 7 and M2I work perfect....maybe something change in 8 or 9 version i dont know....anyone tester??
ibalouka
Post by ibalouka » Sat Nov 04, 2006 4:39 am
well, last night i tried with max9 32bit , worked just fine.
(a part the metal thing)
i just installed indigo her in studio, on max 7 the same problem.
i can't see the nk metal mat. from the material editor....
100% it's my stupidity... :oops:
should i copy the nkdata. folder to some wherelse or leave it in
the indigo dir.??
thanks for the help, :lol: :oops:
afecelis
Post by afecelis » Sat Nov 04, 2006 4:55 am
no, not at all.
Check your m2i.ini file; this sets the path to Indigo which should be:
indigodir=C:\Indigo
or modify it according to where you installed indigo :D
ibalouka
Post by ibalouka » Sat Nov 04, 2006 8:14 am
afecelis wrote:no, not at all.
indigodir=C:\Indigo
:lol: :lol:
that was it. 1000 thanks
afecelis
Post by afecelis » Sat Nov 04, 2006 8:35 am
:D :D :D
u3dreal
Post by u3dreal » Sat Nov 04, 2006 9:45 am
He he :)
Thanks afecelis for helping me out...!!
Well man will test before they go RTFM... :lol:
cheers
have fun with the exporter and let me know when it works ... or when it don't ...
cheers
u3dreal ;)
u3dreal
Post by u3dreal » Sat Nov 04, 2006 9:48 am
psor wrote:Sorry Gregor, I had no spare time to fully check it. I did a quick test
and I was wrong. The error occurs when I hit render in the M2I panel.
Then I do get an information that tells me something like:
"Unknown faceted blahblah..." I'll check it later today and write
it down ... ;o)
btw. it was the 32bit version that I tried Indigo on, not the 64bit as
I stated bevor, sorry ... :P :D ;)
take care
Oleg
Hi Oleg ... i guess there is a wrong material in your scene ... that's usually what i get when using
k-material ... :lol: check it but i'm pretty certain.... i really should go think about adding
an error message here..or maybe a report at the end.
cheers
u3dreal ;)
u3dreal
Post by u3dreal » Sat Nov 04, 2006 12:19 pm
Progress ... :D
I'm happy as a child ... finally i found out how to get the right upvector for the camera..
He he .. so for most of you this might look like a pretty ugly rendering but at a closer look :D
Finally we can make pics with cameraroll !!
been trying this since february..
Let's see where this all end up ... :D
cheers
u3dreal ;)
afecelis
Post by afecelis » Sat Nov 04, 2006 12:32 pm
speechless! :shock: :shock: :shock: Since February? man! you have beaten the challenge!
great work! errm... what's it for? :wink:
Kosmokrator
Post by Kosmokrator » Sun Nov 05, 2006 2:48 am
u3dral u are perfect man...i have this problem wile rotate the camera...when we expect new m2i version??? :D :D :D :wink:
u3dreal
Post by u3dreal » Sun Nov 05, 2006 3:36 am
Well i have to leave now so maybe tomorrow..
cheers
u3dreal ;)
