DEV-thread - Blendigo v0.7 - material-editor-exporter
Post by Kram1032 » Fri Apr 27, 2007 8:57 am
Found one "bug"
It's more a problem than a bug...
Instancing:
1 Mesh that is applied to multiple objects.
I subdivided the objects 2 times...
but sometimes, I oversaw some meshes, that just had subdiv 1 instead...
-> no error, no fullstop and close window, no warning, but an infinite export time... more or less ;)
Can you add an error message for that, that imediately will stop exporting?
zuegs
Post by zuegs » Fri Apr 27, 2007 6:37 pm
@Kram1032: sorry :oops: i can't realy understand what the bug is, can you send me a PM with a german description of the bug please? :roll:
THX :wink:
klopes
Post by klopes » Fri Apr 27, 2007 9:58 pm
Hi all,
Using 'None' environment, my scene contains both lights (even 1 sunlight), and emitter materials, then exporting seems ok, but I get this Indigo error:
'Scene must contain at least one light source'
Any other environment works ok.
DaveC
Post by DaveC » Fri Apr 27, 2007 10:02 pm
With none environment, you don't need emitter materials in the blender sense. You need meshlights, in the indigo sense. Select the object you're using as a meshlight, choose the material (in the blender buttons) to use as a light emitter and choose "Light" type material in blendigo.
Post by Kram1032 » Sat Apr 28, 2007 4:21 am
Blendigo has to get every single Blender Material defined as an Indigomaterial...
If you just want to use Blender internal mats, to set the scene up, you should try Wedges exporter...
It's a bit harder to work with it, but it also is a bit faster...
You decide, what you prefere ;)
Big Fan
Post by Big Fan » Sat Apr 28, 2007 12:01 pm
edited to remove all
DaveC
Post by DaveC » Sat Apr 28, 2007 12:19 pm
I shall download this when I'm finished reinstalling all of my windows software :x
Big Fan
Post by Big Fan » Sat Apr 28, 2007 11:32 pm
drBouvierLeduc
Post by drBouvierLeduc » Sun Apr 29, 2007 12:47 am
Suddenly, blendigo disappeared from the export menu... wtf ?
I checked everything (paths etc..) everything is ok...
Does anyone has a clue ?
(ps : latest blendigo + blender 2.43 from graphicall)
DaveC
Post by DaveC » Sun Apr 29, 2007 1:30 am
It's in the Render menu.
zuegs
Post by zuegs » Mon Apr 30, 2007 9:02 am
@BigFan:
does the preset feature already work in your code?
It's possible that blendigo is a bit slower but from my experiences it should be faster than the half (around 80% i think).
@drBouvierLeduc: yes menu has changed since lest release. It's in the "render" menu now.
Stur
Post by Stur » Mon Apr 30, 2007 10:46 am
For me, the script didn't show up, not even in the "Render" menu. I edited the .py to put the script back to "Export" group, and it worked.
I think the problem has something to do with the error message I get when I launch Blender :
Compiled with Python version 2.4
'import site failed', use -v for traceback
Checking for installed Python.. No installed Python found.
Only built-in modules are available. Some scripts may not run.
Continuing happily.
So, what's that ? Do I need to install something else than just Blender to run Python scripts within Blender ??
Thx in advance for help.
dougal2
Post by dougal2 » Mon Apr 30, 2007 10:47 am
Stur wrote: Compiled with Python version 2.4
Continuing happily.
this is normal.
DaveC
Post by DaveC » Mon Apr 30, 2007 11:12 am
That error message simply means you don't have python 2.4 installed
Stur
Post by Stur » Mon Apr 30, 2007 12:03 pm
And do you have it installed, you whose Blendigo script appears correctly in the Render menu ?
