Blendigo for v1.0.7
JaMon_3D
Post by JaMon_3D » Wed Mar 12, 2008 6:25 pm
Thanks a lot SmartDen!!!
Big Fan
Post by Big Fan » Wed Mar 12, 2008 6:59 pm
um is this actually 1.0.6? :? some bits for 1.0.7 are not there yet... :roll:
Post by BbB » Thu Mar 13, 2008 1:49 am
Yes, it would be nice to get a choice of filters...
Photoguy
Post by Photoguy » Thu Mar 13, 2008 1:53 am
I found that if an object doesn't have any faces, it will crash it.
So watch out, because a lot of my models seemed to have wierd faceless meshes.
Anthor
Post by Anthor » Thu Mar 13, 2008 4:56 am
Tanks for great work :D
I found, there are problem with simply dupliverts.
(translate with google) :oops:
SmartDen
Post by SmartDen » Thu Mar 13, 2008 7:28 am
Anthor wrote:Tanks for great work :D
Sorry Anthor, i didn't made any test with dupliverts. :oops: I'll see what i can do
Anthony
Post by Anthony » Sat Mar 15, 2008 10:46 am
Yay it works. But where are the settings to change post process diffraction, render regions (didnt know we had these but it says "render region:false", MN filter settings etc. Blendigo is the same since the last version I used except for alphamask thingy?
Post by OnoSendai » Sun Mar 16, 2008 8:07 pm
Hi Smartden.
The new version looks good, but there are a few changes I would suggest:
Camera tab
1)
On the camera tab, the settings for aperture shape currently only show up when the aperture diffraction button is enabled. However, aperture shape should be able to be changed whether or not aperture diffraction is enabled. Aperture shape can cause e.g. Bokeh effects even when aperture diffraction is false.
2)
Film ISO should probably go in tonemapping tab under camera tonemapping.
3)
Perhaps rename 'Shutter' to 'Shutter speed' or 'exposure duration'
4) When image aperture diffraction is selected, there doesn't seem to be a form element for setting the path to the image.
Renderer Tab:
5) LM probability and Max change don't seem to export for me (i left them on the defaults you have), which is good, because the LM probability is way too low. Please use my default (0.4)
6) Please change Max num consec. rejections (MNCR) to 1000.
System Tab:
7) I recommend you add a button for 'auto choose num threads', and set it to true by default.
In general:
8 ) Please enable aperture diffraction by default.
In general, please use the Indigo defaults for all settings, as given in the updated 1.0.x Indigo manual (which I will release very soon)
9) 'matDB' preview scene gives a parse error.
SmartDen
Post by SmartDen » Wed Mar 19, 2008 11:27 pm
Little update
Pinko5
Post by Pinko5 » Thu Mar 20, 2008 12:02 am
Tnx Smart!!!
Luca;)
Vanessa07
Post by Vanessa07 » Thu Mar 20, 2008 8:05 pm
:D :D :D thx :D :D :D
Post by Kram1032 » Sat Mar 22, 2008 12:29 am
thx :)
