Blendigo for v1.0.7
Hi Smartden.
The new version looks good, but there are a few changes I would suggest:
Camera tab
1)
On the camera tab, the settings for aperture shape currently only show up when the aperture diffraction button is enabled. However, aperture shape should be able to be changed whether or not aperture diffraction is enabled. Aperture shape can cause e.g. Bokeh effects even when aperture diffraction is false.
2)
Film ISO should probably go in tonemapping tab under camera tonemapping.
3)
Perhaps rename 'Shutter' to 'Shutter speed' or 'exposure duration'
4) When image aperture diffraction is selected, there doesn't seem to be a form element for setting the path to the image.
Renderer Tab:
5) LM probability and Max change don't seem to export for me (i left them on the defaults you have), which is good, because the LM probability is way too low. Please use my default (0.4)
6) Please change Max num consec. rejections (MNCR) to 1000.
System Tab:
7) I recommend you add a button for 'auto choose num threads', and set it to true by default.
In general:
8 ) Please enable aperture diffraction by default.
In general, please use the Indigo defaults for all settings, as given in the updated 1.0.x Indigo manual (which I will release very soon)
9) 'matDB' preview scene gives a parse error.
Camera tab
1)
2)
3)
Renderer Tab:
System Tab:
In general:
