Maxigo 3.0.7
vasco
Re: Maxigo 3.0.7
Post by vasco » Wed Jun 20, 2012 7:25 pm
Hello, how can use Indigo with 3ds max design 2012 then? Do I have to buy an other Software? vray?
Re: Maxigo 3.0.7
Post by lycium » Wed Jun 20, 2012 11:38 pm
IndigoMax is the new natively-integrated 3dsmax plugin, and you can follow its development here: http://www.indigorenderer.com/forum/vie ... =9&t=11300
Subpixel has been making good progress here and hopefully we'll see another update from him soon!
MMK
Re: Maxigo for 3dsmax 2013 ??
Post by MMK » Sat Jul 21, 2012 3:22 am
[quote]hi,
maxigo not written for 3ds max 2013 yet ? , i need maxigo in 3dsmax 2013. thanks a lot.
BartS
Re: Maxigo 3.0.7
Post by BartS » Fri Jul 27, 2012 3:25 am
Yep, it's broken and unusable for Max versions > 2011.
Autodesk changed smth in maxscript implementation and Maxigo code doesn't run as it used to run in older versions.
When installing Maxigo 3.0.7, it asks me which 3DS version I have. 2012, 64 bit *IS* an option. So.... broken, or not?
I know it is usable, since I have 2 computers running 2012 + Maxigo 3.0.7. However, a third one (new), is having the same problem mentioned above. Exporting works fine, but Indigo does not start. I have traced this problem back to 3DS not properly closing the .bat file after export. A copy of the .bat file will start Indigo normally.
Any idea if this is fixable? A setting that needs to be changed? Or in other words - someone have any idea why it works on my 2 other computers?
tar_gniK
3D Software: 3ds Max
Re: Maxigo 3.0.7
Post by tar_gniK » Fri Jul 27, 2012 3:55 am
Install Service Pack 1 and 2 for 3DSMax 2012. After that it should run fine.
BartS
Re: Maxigo 3.0.7
Post by BartS » Sat Jul 28, 2012 9:26 am
It does! Thanks for the quick answer :D
Users browsing this forum: No registered users and 96 guests
