Maxigo 3.0.7
Re: Maxigo 3.0.7
Hello, how can use Indigo with 3ds max design 2012 then? Do I have to buy an other Software? vray?
Re: Maxigo 3.0.7
IndigoMax is the new natively-integrated 3dsmax plugin, and you can follow its development here: http://www.indigorenderer.com/forum/vie ... =9&t=11300
Subpixel has been making good progress here and hopefully we'll see another update from him soon!
Re: Maxigo for 3dsmax 2013 ??
[quote]hi,
maxigo not written for 3ds max 2013 yet ? , i need maxigo in 3dsmax 2013. thanks a lot.
Re: Maxigo 3.0.7
When installing Maxigo 3.0.7, it asks me which 3DS version I have. 2012, 64 bit *IS* an option. So.... broken, or not?Yep, it's broken and unusable for Max versions > 2011.
Autodesk changed smth in maxscript implementation and Maxigo code doesn't run as it used to run in older versions.
I know it is usable, since I have 2 computers running 2012 + Maxigo 3.0.7. However, a third one (new), is having the same problem mentioned above. Exporting works fine, but Indigo does not start. I have traced this problem back to 3DS not properly closing the .bat file after export. A copy of the .bat file will start Indigo normally.
Any idea if this is fixable? A setting that needs to be changed? Or in other words - someone have any idea why it works on my 2 other computers?
tar_gniK
- 3D Software: 3ds Max
Re: Maxigo 3.0.7
Install Service Pack 1 and 2 for 3DSMax 2012. After that it should run fine.
Re: Maxigo 3.0.7
It does! Thanks for the quick answerInstall Service Pack 1 and 2 for 3DSMax 2012. After that it should run fine.
