BinaryPixel viz
10 posts • Page 1 of 1
mirekm
BinaryPixel viz
Post by mirekm » Fri Jul 23, 2010 11:35 pm
Hi guys.
I have done in max 2009 + indigo + Photoshop
Scene has 2,6M poly. Rendertime was 17h by 1300 samples per pixel.
Rendered on QuadCore Q6600 8GB ram.
More my stuf you can find at http://www.binarypixel.eu
*Special thanks to dcm for useful tips and tricks in indigo
Hope you like it :)
[url]http://www.binarypixel.eu[/url]
dcm
Re: BinaryPixel viz
Post by dcm » Sat Jul 24, 2010 12:14 am
Welcome here and congratz to ur 1st upload here. I hope, we`ll some nice artworks in future :D
Re: BinaryPixel viz
Post by StompinTom » Sat Jul 24, 2010 12:45 am
The timber texture looks great! Nice bump and subtle reflection on that. The floor seems a bit too flat... maybe a stronger bump map?
mirekm
Re: BinaryPixel viz
Post by mirekm » Sat Jul 24, 2010 12:54 am
Thx guys.
StompinTom> No i dont wanted use bump in this flor. I wanted floor varnish look.
But, thnx 4 comment.
Re: BinaryPixel viz
Post by Zom-B » Sat Jul 24, 2010 1:19 am
mirekm wrote:StompinTom> No i dont wanted use bump in this floor. I wanted floor varnish look.
you could try a exponent map... its way more subtle then bump... give it a try, just to see the result!
Some things I would like to nitpick on ;-)
- thestones on the back wall... the black one... they look very shiny... like oil... Why not using blend between diffuse & phong for rougher look, like the great wood in the front?!
- the green surrounded boar skin on the right... looks wired... green?!
- the floor and wall wood are quite the same... basically you don't do this in architecture often, do you?
- the Katanas on the wall right... looks like this is a table stand that gets placed on the wall.
- the tulips on the floor look quite dark... try blending them with a Diffuse Transmitter with the same texture to bright up a little and let some light pass through them
Besides this a great first render, congrats!!!
Re: BinaryPixel viz
Post by CTZn » Sat Jul 24, 2010 9:09 am
Superb timber textures in the foreground and very nice work overall, I hope that you are planning to add this image to your portfolio any soon !
Did you displace the surfaces in Max ?
Re: BinaryPixel viz
Post by Headroom » Sat Jul 24, 2010 1:08 pm
Tulips ?
I thought there might be an Indian Sumer going on outside and these are fall leaves blown in through the door.
Very nice concept BTW. Really gives the image a special atmosphere.
Re: BinaryPixel viz
Post by zeitmeister » Sun Jul 25, 2010 4:29 am
Wow and welcome!
mirekm
Re: BinaryPixel viz
Post by mirekm » Sun Jul 25, 2010 9:30 pm
Thx guys 4 your post and comments. I hope, next image will be more precise tunned.
Zom-B> What is exponent map?
Re: BinaryPixel viz
Post by Zom-B » Mon Jul 26, 2010 1:06 pm
mirekm wrote:Zom-B> What is exponent map?
A Exponent map is a map that controls the exponent of the material via a texture (or shader).
In general The Exponent is value from glossy (low exponnet) to sharp reflections (high Exponent) of a phong material.
Controlling sharpness of the reflections via a map can generate some welcome visual imperfection to reflective objects without altering them too much (like with bump maps).
Perfect Glass like floors are simply unrealistic, here using a bummap texture for Exponent map helps selling the image :)
Users browsing this forum: Google [Bot] and 38 guests
