If you could send us the scene file (or post it here) we could have a look at it; recognising such issues and knowing their solutions is quite important to us
Dots & dots...
Re: Dots & dots...
Hmmm, while MNCR=10 will clean up a render a lot, it will also produce a largely incorrect image :/ It's certainly not a "fix" for noise problems, ideally it should be left at the default setting.
Re: Dots & dots...
I think You right man
please give me your mail and I send to you scene.
Thanks for help.
Thanks
Piotr
Thanks for help.
Thanks
Piotr
Re: Dots & dots...
Hey Piter!
..don't lnow if it could be of any help, but I usually get those annoyng light spots when I have a metallic surface too close to an emitter. I see you lamp is metallic: try to paint the lamp's inner face with a simple diffuse white material: it is so overexposed that you ain't be able to see any difference..
Re: Dots & dots...
Hi Pibuz !
Thanks for help
Yes, yes you right about this, fix noise and dots in wooden table. But now I`m working with lycium in this scene and maybe we can fix
Thanks
Piotr
Thanks for help
Thanks
Piotr
Re: Dots & dots...
About the light leak of that board near the ceiling... could it be that the board side is coplanar with the exterior wall ?
If so pull it either within or outside the wall, hoping this helps.
- PowStudios
Re: Dots & dots...
And another question: How much impact on render quality/speed has modeling the walls with thickness?
Pow
Pow
MacBook 2.4Ghz, 2GB + i7-920, 6 GB
My MacBook 'whines': http://www.google.com/search?q=macbook+whine
If anyone has a solution that works pls message!
