SkIndigo 2.2.12 (2.2 Stable)
Post by Whaat » Thu Jan 28, 2010 6:27 am
SkIndigo 2.2.12 (2.2 stable) was quietly released shortly after the release of Indigo 2.2 stable.
You can pick it up at the Indigo SketchUp page.
#Version 2.2.12
#Fixed: material editor not opening in rare situations
#Fixed: IGM loading of absorption layer transmittance parameter
#Changed: improved material preview scenes
What's new in SkIndigo 2.2?
Please let me know if you find any bugs!
Enjoy!
Re: SkIndigo 2.2.12 (2.2 Stable)
Post by Pibuz » Thu Jan 28, 2010 8:30 pm
Thank you a lot Whaat!
In what are the preview scenes improved?
Post by OnoSendai » Thu Jan 28, 2010 9:23 pm
Thanks Whaat!
Stinkie
Post by Stinkie » Thu Jan 28, 2010 9:33 pm
Yeah ... thanks, Whaat. :)
Post by Whaat » Fri Jan 29, 2010 2:40 am
Pibuz wrote:Thank you a lot Whaat!
hmmm....I don't remember every change (it was a long time ago) but here are some:
- fixed a lot of things in the official Indigo preview scene (See this thread)
- changed all scenes to consistent camera tonemapping (should help make the same material look the same in all preview scenes)
- re-balanced preview scene lighting for better previewing of emitting materials
Sinas
Post by Sinas » Fri Jan 29, 2010 8:47 am
Cannot run indigo on mac osx because it wants me to locate indigo.app wich is nowhere to be found in the downloaded items. trough SkIndigo-2.2.12.zip or ist unzipped result.
Stinkie
Post by Stinkie » Fri Jan 29, 2010 9:16 am
SkIndigo and Indigo are separate downloads. You need them both.
Sinas
Post by Sinas » Fri Jan 29, 2010 9:24 am
So I did and installed it in the plugin folder and then replaced it to the Applications folder as suggesteted in one of the forum-articles, but still the same question for indigo.app when starting Sketchup.
Sinas
Post by Sinas » Fri Jan 29, 2010 9:36 am
found three indigo's on my disk cleaned up and now =one is running. Sorry for the bothering, thanks for the swift reply, I am going to try it.
Stinkie
Post by Stinkie » Fri Jan 29, 2010 9:50 am
No problem. Enjoy the app.
Post by Whaat » Fri Jan 29, 2010 10:46 am
Sinas wrote:found three indigo's on my disk cleaned up and now =one is running. Sorry for the bothering, thanks for the swift reply, I am going to try it.
Hi Sinas,
Welcome to Indigo! Please post your experience with SkIndigo OSX. We are keen to make your experience as enjoyable as possible so if you have any comments or suggestions, please let me know!
Post by Pibuz » Thu Feb 04, 2010 5:10 am
Hi there!
I think there should be a little problem concerning the scale between mat preview and actual render, see images attached.
Is this solvable?
in render.jpg (337.31 KiB) Viewed 23173 times
Soup
Post by Soup » Thu Feb 04, 2010 9:41 am
I think it's just a UV issue, the MDB model has just one full UV stretched over the whole thing. For the preview you can either crop your texture a quarter of the size, or somehow edit the UVs of the MDB model.
Post by Pibuz » Thu Feb 04, 2010 8:31 pm
Hi Soup!
I was not referring to the scale of the texture, sorry for not having made it clearer.
I was concerning about the strength of the displacement: preview and rendered material are quite different, and the displace value is 0.006 (meters) for both. So I assume that there is some problems about the strength of the displacement map in the preview scene. That's it.
djegoo
Post by djegoo » Thu Feb 04, 2010 10:22 pm
HI
Oh i am late! Thanks for the new release Whaat.
